why are y'all so down on WD-40?
Old Aug 20, 2010 | 10:58 AM
JohnnyZJ's Avatar
JohnnyZJ
Default why are y'all so down on WD-40?
i've been using that stuff for years, and i've never run into a bolt/axle nut i can't get undone. i've broken wratchets, sockets, bolts, you name it, but WD has always worked for me. i swear by it. its plentiful and cheap, and works good enough for what the average joe needs.
i look at my WD-40 like duct tape; it never leaves my truck as it has so many cool uses. does PB blaster? or <insert rust penetrant here>
now, maybe i'm just like, super strong so i dont' need to knock bolts loose with rust penetrant, but i think you guys are rather harsh towards a tried and true product like WD-40..........
or maybe its just funny to watch people trash it so often and then pimp a product i can't even buy in Canada......... might be great; sorry, i'm not gonna goto the trouble of importing it when my trusty WD is sitting right there.
my apologies for the pewpstorm that i've probably started....
Old Aug 20, 2010 | 11:10 AM
calgaryman's Avatar
calgaryman
Hey look Wd-40 also cures Arthritus
http://www.thesun.co.uk/sol/homepage...icle264652.ece
WD-40 was meant to displease water not rust
I will stick by PB blaster... it has worked magic on many a bolts.
We use salt on our roads here in Calgary. so rusted bolts are a major problem even on the simplest repair. PB blast has never let me down (only bolt I had trouble with while using PB blast was my axle nut).
Johnny is about the size of a average Line Backer in the NFL... I'm sure he could spray water on a bolt and then uses his bear hands and it would come loose.
Old Aug 20, 2010 | 11:13 AM
calgaryman's Avatar
calgaryman
BTW Johnny... How did the WD-40 work on your front drive shaft bolts... Didn't you have to buy a new yok?
Sorry had to say it
Old Aug 20, 2010 | 11:15 AM
Sheriff420's Avatar
Sheriff420
WD-40 is good for a quick lube on a pulley or a hinge (quick because it dries and starts squeaking again before too long), on rubber worms when fishing and a few other uses but it isn't a good penetrant because it is a lubricant, not a penetrant.
You wouldn't have broken those ratchets, sockets or bolts if you had used a good penetrating fluid.
PB blaster is a lube just like WD-40 for what its worth.
Old Aug 20, 2010 | 11:21 AM
JohnnyZJ's Avatar
JohnnyZJ
[quote=Sheriff420;2237797]
quote]
really? that statement right there made my day.
maybe they should be selling good penetrating lube with wratchet sets then and forget about warranties
so you're saying if i use a good penetrant i won't need to put that 4ft breaker bar on the axle nut to pop it loose? cause last time i checked, 4 ft breaker bars have a tendency to break stuff...............
Calgary man, NFL linebacks WISH they had shoulders like mine..........
Old Aug 20, 2010 | 11:27 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Just curious how you walk with such a large, dangly pair
Old Aug 20, 2010 | 11:29 AM
The "WD" in there is "water displacing". That is its major purpose. I have used WD-40, and PB-Blaster. I like the PB MUCH Better. Haven't tried the other products plugged here.
Old Aug 20, 2010 | 11:43 AM
JohnnyZJ's Avatar
JohnnyZJ
truth be told, the best thing i've found for siezed bolts is.................... heat, and lots of it......
or maybe i just like burning things
if the bolts big enough, then brute strength should knock it loose and it its smaller, get it so hot its red
Old Aug 20, 2010 | 11:45 AM
JohnnyZJ's Avatar
JohnnyZJ
i'm actually overcompensating for certain inadequacies
Old Aug 20, 2010 | 12:02 PM
Alright. That's IT. You owe me one monitor cleaning.
