Underhood light
Old Aug 21, 2010 | 04:55 PM
redheadhunter21's Avatar
redheadhunter21
Default Underhood light
Ok does anybody know what causes it to turn off when you close the hood and also what fuse it uses, I tried to use it for leds and they stay on constant so need to unplug the fuse for now so I can figure out why its not turning off when the hood closes
Old Aug 21, 2010 | 05:04 PM
xjarhead69's Avatar
xjarhead69
I was told by the parts guy at the dealer that the switch is built into the light,
kind of works like the old mercury home thermastat for your furnace.
Dave
Old Aug 21, 2010 | 05:05 PM
pcfixerpro's Avatar
pcfixerpro
Pretty sure it is is a mercury switch? To keep the led's from lighting with the hood shut, you will need to install a resistor.
Old Aug 21, 2010 | 05:06 PM
olyelr's Avatar
olyelr
Yep, mercury.
Old Aug 21, 2010 | 05:07 PM
olyelr's Avatar
olyelr
Is that the same as a flux capacitor?
Old Aug 21, 2010 | 05:14 PM
lord0fsal3m's Avatar
lord0fsal3m
yea i just replaced my light bulb and it was an interesting contraption. so i just shruged and left it alone. lol.
pcfixerpro's Avatar
pcfixerpro
lol why, are you looking for a flux capacitor? I might have one laying around hahaha. Nah I was refering to this type of resistor. We used this specific one on my buddy's 08 ram because he swapped to led dome, led map, and they would stay dimmly lit even with the doors shut.
http://tinyurl.com/2frhoyg
Old Aug 21, 2010 | 05:16 PM
redheadhunter21
F^ck ok does anybody know what fuse it uses, Its raining outside and im trying to get it so I can drive my truck tomarrow without having to cut my wiring, so if I just pop the fuse out ill be good
Old Aug 21, 2010 | 05:54 PM
pcfixerpro's Avatar
pcfixerpro
My wiring is most likely different in my 01. Grab your manual out of your glove box. Also, doesn't the light have a wiring connector on it? pop the connector if you can't find the fuse.
Old Aug 21, 2010 | 07:29 PM
olyelr's Avatar
olyelr
Yes, the light has a connector for sure. But, he probably tapped in well before that, so it will most likely not do him any good... although I'm not the electrical guru here.
And yes, I am in need of a few flux capacitors if you have a few handy.
