help 318 knocks when cold
Old Aug 22, 2010 | 04:58 PM
benm2717's Avatar
benm2717
Default help 318 knocks when cold
i have a1997 dodge ram 1500 and i changed the oil pan gasket cause it was leaking and i put it all back together and new oil and filter and now it knocks when i start it up after it cools down it never did it before and i just don't understand why now
Old Aug 22, 2010 | 05:05 PM
Dry starts..... Can you tell what flavor of knock? Rod or Main? Other?
Old Aug 22, 2010 | 06:04 PM
dhvaughan's Avatar
dhvaughan
is it a temporary knock or a permanent knock?
when i replaced my oil pump i put the dust cover on wrong and the flex plate hit it, causing a permanent knock. redoing the dust cover correctly fixed it.
Old Aug 22, 2010 | 06:54 PM
benm2717's Avatar
benm2717
no it goes away about 15 min of driving it but it sounds like it is coming from underneath i put a senthetic blend it i don't know if that would cause that or not it is a steady knock then it kinda makes a gurgling knock but when i put it in gear its not has bad or stops but park its there until it warms up
Old Aug 22, 2010 | 08:47 PM
dhvaughan's Avatar
dhvaughan
could anything have happened to the oil pickup tube during the oil pan gasket change?
Old Aug 22, 2010 | 09:16 PM
benm2717's Avatar
benm2717
there is always that possiblity but why would it go away after it warms up
Old Aug 22, 2010 | 09:19 PM
techmike's Avatar
techmike
What's the oil pressure at when you start it and after it warms up? How many miles on the engine? If I read your post right it's quieter under load (in gear) and louder when not (in park)?
Old Aug 22, 2010 | 09:25 PM
benm2717's Avatar
benm2717
it reads a little past 40 on start and about half way between 0 and 40 it has 160000 miles and it is quiter under load
Old Aug 22, 2010 | 10:19 PM
Is the oil level up to snuff? Pressure should go UP with RPM, especially with a new oil pump.
Whats the pressure at idle when warm?
Old Aug 22, 2010 | 10:43 PM
techmike's Avatar
techmike
Sounds like an oil delivery problem if oil pressure drops with higher RPM's.
