wheel bearings
Old Aug 26, 2010 | 09:33 PM
willstruck's Avatar
willstruck
Originally Posted by dhvaughan
on d44 the axle seals are down at the diff and cad. i don't know about d60, but i think its the same.
This just occurred to me today. What side of the CAD is the seal on? Outside, or inside the CAD? I never thought about it, I just assumed there was no problem, but when I took the CAD off, diff fluid poured out. Maybe it's normal, but today it occurred to me that I don't know if it's normal or not, maybe the seal is on the inside of the CAD...
Old Aug 26, 2010 | 09:38 PM
Seal is outboard from the CAD. Fluid coming out is indeed normal.
Old Aug 26, 2010 | 10:53 PM
willstruck's Avatar
willstruck
Awesome possum.
Old Aug 27, 2010 | 04:16 AM
bigslick050's Avatar
bigslick050
Only paid $165 for my hub bearing at Napa...
Old Aug 30, 2010 | 11:34 PM
willstruck's Avatar
willstruck
Well, I thought I could hear the noise from the drivers side, but the passenger side sounds pretty bad when it's lifted, and I spin the wheel.
Got the bearing and bushing from quad4x4, replaced the bushing which was all messed up. The bearing was in there pretty good, and it was fine, so I didn't replace it. Still wouldn't go into 4wd. We decided to slide the collar over to keep it locked, and used nuts to space the fork so it would always be locked, but took out the c clips. So, I have the same effect as a solid axle, and when I put my t case in 4, the pin still slides and hits the switch to turn on the 4x4 light.
Old Aug 31, 2010 | 07:31 AM
dhvaughan's Avatar
dhvaughan
is is still apart or did you put it back together yet?
if still apart, pull the passenger side inner and outer axle out and take to the work bench and see whats wrong with the slide collar. caution - this probably requires replacement of passenger side oil seal.
