EGR Delete
Old 08-24-2010, 01:08 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
Default EGR Delete
Is it possible to delete the EGR valve on a '96 5.9?
What would be the benefits of this?
Old 08-24-2010, 03:12 PM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
i have mine blocked off due to non egr headers....no difference that i could tell....
Old 08-24-2010, 03:19 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
How did you block it off?
Old 08-24-2010, 04:00 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
96 should not have one
i blocked mine by putting a piece of metal between the erg pipe and the exhausr man
Old 08-24-2010, 05:05 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
No EGR in 96 (at least on Dakotas). Mine is gone because of a non-EGR M1, I took the tube off the manifold, cut it, then pinched it in a press and bolted it back on.
Old 08-24-2010, 05:14 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
Everything I have seen had one on the '96 models. Hmmm, now I am gonna go look.
Old 08-24-2010, 05:23 PM
J McWillis's Avatar
J McWillis
J McWillis is offline
I thought '97 was the year they did away with them?
Old 08-25-2010, 02:30 AM
dakotas ram
i believe 96 was a split year......i just made a little plate to bolt on the end of the tube and left everything else hooked up...i get a code every great once in awhile
Old 08-25-2010, 08:38 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,393 Likes on 3,133 Posts
My 96 does not have EGR.
Old 08-25-2010, 09:45 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
i deleted mine in my 95, deleted pipe, (had ends welded closed) and the new manifold i bought when doing plenum had a piece to block off the egr....no difference what so ever, get a CEL like once every 3000 miles, andwhen i shut truck off and turn it back on theres no CEL
Quick Reply: EGR Delete
