front axle noise
Old Aug 25, 2010 | 04:05 PM
chrismar101's Avatar
chrismar101
Default front axle noise
I've been hearing a weird noise coming from my front passenger side tire. I thought it was a rock in the break...but wasn't. I jacked it up and removed the tire and didn't see anything. Then i spun the shaft and heard a clunking, rattle noise. Sounded like it was coming from inside the axle...It is 4x4...the noise speeds up as the truck does. I've been driving on it for a month now and it hasn't got any worse...
Any ideas...suggestions
Thanks
Old Aug 25, 2010 | 06:31 PM
Possibly bearings/bushings just inside the axle tube. Pull the CAD unit off, and have a look inside. See if anything is obvious.
Old Aug 26, 2010 | 01:14 AM
dhvaughan's Avatar
dhvaughan
check axle u-joints for any play by twisting them. see if it makes a click-click or clack-clack sound.
if not bearings or u-joints, put it up on jack stands and follow the noise. check at the cad cover. rear side of passenger side axle. have a drain pan handy, as a cupful of gear oil will come out. your shift fork and collar might be dragging on the inner axle.
