No fire and coil is good, now what ?
Old Sep 19, 2010 | 07:12 PM
  #31
Gary-L's Avatar
Gary-L
Veteran: Navy
Get a new distributor cap.
Old Sep 20, 2010 | 01:16 PM
  #32
Ramulator's Avatar
Ramulator
New cap didn't help .... can someone confirm this firing order is right , 1996 ram 1500 , 5.9 l
1-8-4-3-6-5-7-2 pass side 2-4-6-8 , drive side 1-3-5-7
I have over checked this at least 7 times and i have it right as above. But the truck acts like the firing is mixed up , don't know where to look now , unless i try the old crank sensor back on it as it wasn't the original problem to start with, the pick up was the culprit.
Old Sep 20, 2010 | 01:28 PM
  #33
Gary-L's Avatar
Gary-L
Veteran: Navy
^^ Best thing to do is to remove all of the spark plug wires from the plugs and then completely from the distributor cap. Remove the distributor cap, install the plug wire for #1 onto the distributor cap, reinstall the distributor cap, connect the wire for #1. Then, work either clockwise or counter-clockwise to install the remaining wires. It is best to follow the procedure as laid out in the TSB. I encountered this once after installing a new cap and found it much easier to just start from scratch.
Old Sep 20, 2010 | 04:39 PM
  #34
Ramulator's Avatar
Ramulator
I got it going , the "new" crank sensor i purchased from ebay was not working, i put my old one back on and she fired right up . Ebay junk !!
Old Sep 20, 2010 | 04:48 PM
  #35
Gary-L's Avatar
Gary-L
Veteran: Navy
Sounds like it was originally your distributor cap.
Old Sep 20, 2010 | 07:30 PM
  #36
Ramulator's Avatar
Ramulator
Could have been, nothing kicked over till i put in the new pick up , But it definatly needed a new cap, old one was spent .... Thanks for helping me out !!!
Old Sep 21, 2010 | 12:59 PM
  #37
cmckenna's Avatar
cmckenna
If the CKPS sensor is NOT OEM, this is a "bonus" feature. I've had this happen to me twice - Napa and Pep Boys junk sensors coming out of Taiwan and Mexico remakes- total garbage.
Clean and re-install the old sensor. NOTE: apply a small amount of mineral oil to both seal and sensor body (NOT SENSOR FACE) This shall correct that issue. Yes, the firing order is the same for both 5.2 and 5.9 so, you've got it correct there.
CM
