No fire and coil is good, now what ?
Old Aug 27, 2010 | 02:46 PM
Ramulator's Avatar
Ramulator
Default No fire and coil is good, now what ?
My 96 ram 5.9 L has stopped firing for some reason, i have installed a new ignition coil and still no fire, also i tested and have good power supply to the coil....so where else to look ? someone suggested the crankshaft positioning sensor , could this be the culprit ? how can i test it ? The truck started skipping like it was running out of gas, i shut it off and added some gas because the gas light was on, had 1/4 of a tank and tried to restart, it kicked a few times and ran for 10 seconds sputtering and now is dead, but it definatly has no fire through the plugs.
Old Aug 27, 2010 | 02:47 PM
crank or cam position sensor most likely. Not aware of any way to test either...... Short of being able to see the data while cranking....
Old Aug 27, 2010 | 02:52 PM
Ugly1's Avatar
Ugly1
Are the spark plugs sparking? Maybe coil wire?
Old Aug 27, 2010 | 03:06 PM
Ramulator's Avatar
Ramulator
No spark at the plug at all, dead. The crank sensor looks like a real SOB to get at . Where is the cam sensor on my 96 ram, please don't say distributer because i can hardly see the distributer on this rig.
Old Aug 27, 2010 | 03:09 PM
Ugly1's Avatar
Ugly1
It could be something as simple and cheap as a fualty coil wire. You know, the one in the center of the distributor.
Old Aug 27, 2010 | 03:14 PM
Ramulator's Avatar
Ramulator
I'll check it , i had one burn to my manifold once and ground out, that messed the firing up bigtime.
Old Aug 27, 2010 | 03:27 PM
mjonesjr's Avatar
mjonesjr
Check the timing.
Old Aug 27, 2010 | 04:09 PM
Ramulator's Avatar
Ramulator
The coil wire visually looks alright , i got the crank sensor out, wasn't as bad as i thought, used a stuby ratchet and went in from the top by feel , had to remove the tranny dip spout bracket bolt also by feel to get at the inside sensor bolt but wasn't too bad. Now to find a used one somewhere to try, the dealership told me any sensor off a 6 or 8 cylinder dodge truck motor would work as long as it was automatic tranny.
Old Aug 27, 2010 | 04:38 PM
Ugly1's Avatar
Ugly1
That probably means it's fine but still is no guarantee. I actually have had one be intermittent and look fine before.
Re CPS: is yours OBD1? I ask since mine is and you can do the 3X ignition trick to get the codes. Mine threw a code when the CPS went. It might be worth it to pull the codes just to see what's in there.
Old Aug 27, 2010 | 04:51 PM
Ramulator's Avatar
Ramulator
I buddy up the road has a canadian tire code reader , not sure if it will work on my truck, what kind of reader do i need for my 96 ram and where do i plug it in ?
