Help would be appreciated.
I have 99' dodge ram 1500 5.9L 4WD. I have engine problems and have found a engine in a 94' dodge ram 2500 5.9L 2WD.
I am thinking most of the other engine will fit just not sure on the transmission and transfer case, and also the ECM.
I have done some checking on parts. Most of the parts are the same between the 2 different years.
Thanks for the help.
frank
frank
94-95 is OBD 1 and 96+ is OBD2, so its major difference in ECM and wiring.
transmission is hugely different.
the basic engine is the same. if you install the 94 engine ONLY, and move the 99 intake and ALL sensors over to the 94 it will work. do not use any wiring or sensors from the 94. edit - unless you prove they are interchangeable by checking parts catalog and visual plug check.... assume they are not interchangeable....
