Rear differential confusion- and how much and what type of oil?
Old Aug 28, 2010 | 02:27 PM
Arachnyd's Avatar
Arachnyd
Default Rear differential confusion- and how much and what type of oil?
I'm so confused.
The manual says 75W-90 UNLESS its a Dana 60. 70, 0r 80. How can you tell?
Dodge also told me I need 4.5 Quarts. 4.5 quarts of gear oil??? wtf?
Autozone says there is no LSD on 9.25 rear axles. For 9 1/4 they said its 2.5 PINTS. Well I have my build sheet and it says:
9.25 LD Rar Axle, 3.55 Rear Axle Ratio, Anti-Spin Differential Rear Axle
Does that mean I don't really have 9 1/4, I don't really have LSD, or I have one of those other Dana rear ends?
Either way, one of the three of us is wrong, so Help is appreciated!
Thanks!
Old Aug 28, 2010 | 03:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Post your build sheet here. And post all the info about your truck instead of leaving us guessing.
Old Aug 28, 2010 | 03:18 PM
dhvaughan's Avatar
dhvaughan
all 1500's have the chrysler 9.25 (9-1/4).
anti-spin is the same as limited slip. you have it. which means you need the little 8 oz bottle of friction modifier, available at any parts store.
any multi-grade gear oil is fine 80w90, 85w90, or the expensive 75w140. it doesn't really matter.
you need 2.5 pints, which is 1.25 qts, so you need to buy 2 qts.
use black rtv as a gasket. orange looks silly.
there. confusion solved.
Old Aug 28, 2010 | 03:22 PM
Arachnyd's Avatar
Arachnyd
Your a lifesaver. Thats exactly what I needed to know!
Thanks a lot, now I'm good to go!
Thanks!
Old Aug 28, 2010 | 03:44 PM
zman17's Avatar
zman17
So the 9 1/4 corporate rear end needs the additive?
Old Aug 28, 2010 | 04:03 PM
Raine883's Avatar
Raine883
And dont trust autozone, i worked there for a while during high school. They will literally hire just about anybody regardless of there automotive knowledge. Im running lucas 85w90 with lucas lsd additive.
Old Aug 28, 2010 | 04:24 PM
zman17's Avatar
zman17
If the corporate 9 1/4 needs the additive, then that might explain a lot of probs people have on here with there rear diff.
Old Aug 28, 2010 | 08:30 PM
redheadhunter21's Avatar
redheadhunter21
They only need the additive if its a limited slip and most of the 75w140 gear oils do not require it because it is already in the gear oil, I went with Valvoline syntec 75w140 and havent had a problem actually helped the limited slip compared to the old oil
Old Sep 13, 2014 | 12:49 AM
GRed's Avatar
GRed
So Im getting ready to mine.. and found this bottle I purchased it is 80w140 this should be ok..??? its limited slip oil.. and does that mean I don't need that bottle of friction modifier ??
Old Sep 13, 2014 | 10:49 AM
Should already have the modifier in it. Fluid will be fine.
