Cylinder Misfire before it get warmed up
Old Sep 3, 2010 | 12:53 PM
sk8erdude's Avatar
sk8erdude
Default Cylinder Misfire before it get warmed up
so i still have a cylinder 4 misfire and i still havent fixed it. dont really want to spend the money to get it fixed. but it baffles me, when i first start it up and drive it you can hear it missing and popping, every few engine rotations it will fire. if i get on it for a 1/8th of a mile the cylinder will go back to running fine. i get all my power back and it sounds like it should. what the heck causes this? the last time i checked for compression i was at 90 psi dry and 120 psi wet. is 120 enough for the cylinder to start firing right again? or does it have something to do with heat?
Old Sep 3, 2010 | 01:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Just thinking out loud, but could it be a bad plug wire at the connection? Once it gets warmed, the metal expands enough to prevent further issues.
Old Sep 3, 2010 | 05:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the injector wire and plug too. Actually, that could be a sticking valve or valve seat maybe.
Old Sep 3, 2010 | 06:01 PM
Dodge says minimum is 100 lbs too..... when was the last time you looked at that plug? Is it oil fouled?
Old Sep 4, 2010 | 12:51 PM
sk8erdude's Avatar
sk8erdude
the plug isnt fouled. it looks to be alright to me. is there any way i can check for a stuck valve? maybe check for compression when its cold and then check it again when its warm?
Old Sep 4, 2010 | 01:02 PM
zman17's Avatar
zman17
Crank Position Sensor.
Old Sep 4, 2010 | 01:19 PM
sk8erdude's Avatar
sk8erdude
what about it? lol
use that to see if i have a stuck valve?
Old Sep 4, 2010 | 03:05 PM
zman17's Avatar
zman17
No! LOL sorry. 9 times out of ten, if it dies or won't start after it's warmed up, the CPS is the prob.
Old Sep 5, 2010 | 08:16 AM
atlrus's Avatar
atlrus
With the engine running unplug the injector plug and check the resistance with a volt-meter: it should be between 13 and 15 ohms.
Old Sep 5, 2010 | 09:25 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Muffler bearings could be stuck causing a restriction in the exhaust port.
