Not enough Alternator
Old 09-06-2010, 08:06 PM
Flue's Avatar
Flue
Flue is offline
Default Not enough Alternator
In case your wondering...and I know you are. The stock 90amp alternator in my truck is NOT enough to drive both the Taurus fan and the A/C. dam! I forgot that I WAS going to upgrade to 136.
Had been putting off hooking up the hi speed side all summer, then I had a wiring epiphany, the A/C relay is a DP/ST. You can use it to isolate the low speed temp side when the A/C is on.
But seems the 9amps the low side is drawing is too much when the A/C is on. Cycling is not a good thing. Lease now I have a "need" to put in the 136 now.
Old 09-06-2010, 08:34 PM
Aubrey's Avatar
Aubrey
Aubrey is offline
How is your fan and your a/c drawing too much while driving? That fan must use a LOT of power!
Old 09-06-2010, 09:15 PM
notanexit7's Avatar
notanexit7
notanexit7 is offline
Why did some trucks come with a 90 and some with the 136?
Old 09-06-2010, 09:19 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
If you go looking at the 170A alternators with external rectifiers you might conclude that it's cheaper to replace the fan setup than the alternator.
Old 09-06-2010, 09:38 PM
Flue's Avatar
Flue
Flue is offline
The Taurus fan is a hog. The alternator in the car was/is 130 amps. A 136a for the 1500 should be a good match for this setup.
If it won't pull both the A/C and e-fan while sitting in the drive way I'll not use the A/C while driving until either the power issue is resolved, or I go back to a *gasp* mechanical fan . I'd rather roll the windows down then chance messing something up.
Old 09-06-2010, 09:39 PM
Flue's Avatar
Flue
Flue is offline
Didn't the majority come with 117? That one seems to be the most numerous at the salvage yards.
Old 09-06-2010, 09:59 PM
notanexit7's Avatar
notanexit7
Your right, my bad
Old 09-06-2010, 10:23 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
They make an alternator/***** pump combo? Badass!
Old 09-06-2010, 10:30 PM
a-master's Avatar
a-master
a-master is offline
my manhood would never go anywhere near anything that is connected to my engine's moving parts haha
Old 09-07-2010, 12:31 AM
UnregisteredUser
Ya done lost me there, squirrels...
Quick Reply: Not enough Alternator
