hub bearings, happy b-day :(
Old Sep 8, 2010 | 10:38 PM
lord0fsal3m's Avatar
lord0fsal3m
Default hub bearings, happy b-day :(
well happy b-day to me, drivers hub bearing and tie rod end need replacing, just wondering, i know i have ABS but how do i know if its 2 or 4 wheel? and are there differences in the assemblys?
Old Sep 8, 2010 | 10:41 PM
lord0fsal3m
will this work? seems really underpriced?
http://cgi.ebay.com/ebaymotors/2-Fro...Q5fAccessories
Old Sep 8, 2010 | 10:51 PM
lord0fsal3m
this is the tie rod end that needs replaced, on the left of the rotor. im assuming thats called an outer? moog? suggestions?
Old Sep 8, 2010 | 10:58 PM
FarmBoy428's Avatar
FarmBoy428
Sexy drilled an slotted rotors* I know its way off topic bro but how much did those run ya?
And I think its a outer don't bi*ch me out if i am wrong.
HAPPY BIRTHDAY LORD!
Old Sep 8, 2010 | 10:59 PM
FarmBoy428's Avatar
FarmBoy428
p/s you leakin oil, or tranny fluid?
Old Sep 8, 2010 | 11:22 PM
dodge15004x45.9's Avatar
dodge15004x45.9
You don't have ABS in the front my 01 does not. If you have ABS you will see 2 lines on the back side of the hub.
Old Sep 9, 2010 | 12:03 AM
olyelr's Avatar
olyelr
Not necessarily true, he could have it.
All the second gens have rear wheel ABS, but the front is an option. The bearings are a little different, as the one with ABS has a wire going to it. If you don't have ABS either one will work, but if you do have ABS you will need one with the wire, otherwise your Brake and ABS light will be on (and the system will not function properly).
Old Sep 9, 2010 | 12:19 AM
dodge15004x45.9
I covered my *** there and explained it.
Old Sep 9, 2010 | 04:12 AM
dakotas ram's Avatar
dakotas ram
i wouldnt buy those cheapies from ebay, prob be doin it agian pretty soon, yeah that is the outer tie rod, o reillys should have moog in stock
Old Sep 9, 2010 | 06:12 AM
lord0fsal3m
no oreilys around here. no thats brake fluid from pushing the calipers back and the ebc D/S i got for $130 and the ebc green stuff pads i got for $40 on ebay
