Sway Bar issue
Old Sep 13, 2010 | 02:58 PM
TimSully88's Avatar
TimSully88
Default Sway Bar issue
So I was installing some Fisher Push plates on my truck this morning and upon reassmbly, I stripped out a sway bar mount on the drivers side. Both bolts are in on the passenger side but on the drivers side, one is tight, the other is completely stripped.
I need to do some driving tomorrow and I was wondering how serious this is??
Thanks for your input.
Old Sep 13, 2010 | 03:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not very! Some people on here have removed or disconnected it from the links with no ill effects.
Old Sep 13, 2010 | 03:33 PM
zman17's Avatar
zman17
PM olyelr. IIRC he has is off.
Old Sep 13, 2010 | 05:45 PM
UnregisteredUser's Avatar
UnregisteredUser
Just completely remove the sway bar, and don't go road racing with the truck. You'll get more front-end roll, but not a frightening amount. When you have the time, throw a Heli-Coil into the stripped hole and put the bar back. Or don't, if you don't mind the front-end roll -- or like having more suspension travel when off-roading.
Old Sep 13, 2010 | 05:55 PM
sk8erdude's Avatar
sk8erdude
i took mine off, didnt really notice anything change...
Old Sep 13, 2010 | 07:52 PM
TimSully88's Avatar
TimSully88
Thanks for the info and advice. I will probably remove it for peace of mind and try the heli-coil trick.
Old Sep 13, 2010 | 08:23 PM
DukesOfHazzard's Avatar
DukesOfHazzard
I wouldnt go the heli coil route but re tap it, IMO and mines been off for last 8 months with little to no effect , except Heavy crosswinds
Old Sep 13, 2010 | 09:33 PM
dsertdog56's Avatar
dsertdog56
I'd probably fix your mount with that extra front weight on board. Sway bars are there for a reason.
Old Sep 16, 2010 | 12:51 AM
97ramnj's Avatar
97ramnj
i took mine off last year and can definitely tell a difference turning, BUT when i do my axle swap i got a HD rear dana 80 with a sway bar back there so, ill prob be putting both on since the paint will be done as well and no more offroading ='[
