99 Ram bad noises
Old Sep 18, 2010 | 06:32 PM
kjsimz1103's Avatar
kjsimz1103
Default 99 Ram bad noises
Hi. thanks for any help youll be able to give. what happened was.
i was going down the highway and my check engine light started to flash 3 or 4 times i think. so i slowed down. and my problem now is that going over 55 it shakes like crazy and when i get over about 2 thousand rpm and going more than 20mph i hear a rattling noise. the check engine light didnt come on after that
its a 99 ram 1500 extended cam 318 v8 4x4.
Thanks again
Old Sep 18, 2010 | 06:35 PM
DamascusKnifemaker's Avatar
DamascusKnifemaker
Can you pull the codes from the PCM?
Does the engine seem okay when idling?
My guess is you have a transmission issue but without more info it is going to be tough to be sure.
Old Sep 18, 2010 | 06:37 PM
Probably missing. Should get the codes read, and see what they have to say. Could be any number of reasons for a miss. Plenum bad, fouled plugs, bad fuel pressure, bad plug wires/cap/rotor.... etc.
Is it worse at about 45, when the TCC engages, and in fourth gear?
Old Sep 18, 2010 | 08:03 PM
kjsimz1103's Avatar
kjsimz1103
well the faster it goes the worse the shaking is. and the noise i only hear at about 2200 rpm. and it seems fine when idling
thanks
Old Sep 18, 2010 | 08:32 PM
Tough Ram's Avatar
Tough Ram
could be clogged cat for the rattling noise. as for the shaking i dont know. could be front u joints going bad and shaking so bad that it is messing with the wheel speed sensor if you have them.
Old Sep 19, 2010 | 04:04 AM
99redram318's Avatar
99redram318
My guess is clogged cat, and for the miss, wires, cap, plugs, plenum, hmm
Old Sep 19, 2010 | 09:17 AM
kjsimz1103's Avatar
kjsimz1103
yeah. i remember we replaced the cat once. HOPEFULLY tis not a trans issue
thanks for all the help guys
Old Sep 19, 2010 | 10:46 AM
CSCustomCars's Avatar
CSCustomCars
Flashing cel is severe misfire, the shaking can be from a misfire thats bad enough, but your cel should have stayed on for that.
You really should pull the codes, then come back and post them. Not sure if your in the US or Canada, Mexico, or across the big blue, but, find a place that will plug in your truck and find out what codes are stored.
Old Sep 19, 2010 | 10:53 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You can also try this, https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Sep 19, 2010 | 07:29 PM
kjsimz1103's Avatar
kjsimz1103
is it ok to drive it like this to class and then to the garage? it still starts and everything just cant go over 55
