how many miles is to many
Old Sep 24, 2010 | 08:33 AM
Bi0sC0mp's Avatar
Bi0sC0mp
Default how many miles is to many
looking at a 2001 dodge ram 1500 from the looks of it been well taken care but it has 198,000 miles and this would be a daily driver so.. how much more miles could this dodge go and is this to high of miles thanks
Old Sep 24, 2010 | 09:06 AM
Laramie1997's Avatar
Laramie1997
It's all dependent on how it was treated, what was repaired.... etc etc
Several people here with over 200K on their DD.
Old Sep 24, 2010 | 09:35 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
213K here and gearing up for a trip to Colorado!
Old Sep 24, 2010 | 09:48 AM
rwisaacks's Avatar
rwisaacks
214,800 on my daily driven Ram.
Old Sep 24, 2010 | 09:59 AM
Bi0sC0mp's Avatar
Bi0sC0mp
new wheel bearingsand trans mount, fornt universals, and upper and lower
a arm bushings, steering shock, tracking bar all new , oil changed, inner and outer tie rods thats the new stuff on it.. not sure if it still be worth it though kinda of scared with tat many miles and driving it everyday
Old Sep 24, 2010 | 10:36 AM
charlie1935's Avatar
charlie1935
If you're leery of it don't buy it.
Old Sep 24, 2010 | 11:24 AM
Jr. Mechanic's Avatar
Jr. Mechanic
If the truck itself is in good shape it will run as long as you want it to. It just depends on what you're willing to fix. It should be good for a little while if there's no apparent noises or problems, but eventually you'll start having major problems like the engine, transmission, and differential (s). It's just inevitable when you buy a high mileage truck. In my opinion if you're getting a good deal on it and it's in good shape, I wouldn't worry about it until something breaks, then fix it. You just have to make peace with the fact it is a high mileage truck before you buy.
Old Sep 24, 2010 | 08:22 PM
Andrew2500's Avatar
Andrew2500
Unless it's cheap, I wouldn't buy an '01 with that many miles. That many miles on a nine year old truck means that it's been driven hard. Majority of the miles are probably good highway miles, but like a previous poster stated, you're gonna start running into problems. Little problems will start to come up and the truck will nickel and dime you until something big goes. Like, for example, the transmission. Then you have to make a decision as to whether or not to dump $2,000 on a truck with 250,000 miles on it.
Old Sep 24, 2010 | 08:30 PM
98Blue-Ram's Avatar
98Blue-Ram
196XXX and running strong...ish
valve cover gaskets seep and rough idle, but still drive it every day and have had no major problems(knock on wood)
Old Sep 24, 2010 | 10:41 PM
notanexit7's Avatar
notanexit7
I've got 247k right now. You'll be fine. I'd trust my truck to make a trip to California and back. It really all depends on how well the truck has been taken care of and if the weak spots on the truck have been replaced or upgraded like plenum, steering, transmission and what have you.
