What transmission is a DGB?
Old Sep 26, 2010 | 04:36 PM
jasonw's Avatar
jasonw
Site Moderator
Thats what all my research pointed to. They switched the Dodges to the RE trannies when they converted them to OBD II.
If I am mistaken on that, and you can prove it, I will change the FAQ.
Old Sep 26, 2010 | 10:36 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Not saying you are mistaken, I just found that interesting if it is indeed true. Jeep used the 46RH until '96 as well (when they converted to OBD II), but started using the 42RE after the first quarter of ZJ production in 1993. You would think if a Grand Cherokee (built very similar to 2nd gen rams, kinda like a little brother) had the 42RE, Dodge would have been using it as well (although the 242 I6 and 3.9L Magnum have different bell housing bolt patterns, so I suppose it isn't too far fetched).
Old Sep 27, 2010 | 10:28 PM
helm's Avatar
helm
Originally Posted by xjarhead69
Call your local Dodge dealer parts dept.
Have your vin number available and they can print build sheet for you for free.
Dave
I went to the Dodge parts counter and gave them my VIN and they gave me the build sheet just like you said.
I had no doubt that I had a 46RE as you all told me that.
It was still nice to see it on the build sheet...along with all the other information.
It's kind of surprizing to see Dodge put a 46RE in a half ton as the GVW for a half ton is 7000 pounds. The 42RE is rated at 7800 pounds. The 46RE is rated at 14,000 pounds.
Automatic Transmission Specs
4-Speed Overdrive Gear Ratios
Automatic Transmission ...42RE.... 46RE.... 47RE
Order Code ......................DGK......DGT..... DGP
1st Gear ..........................2.74..... 2.45.... 2.45
2nd Gear .........................1.54..... 1.45.....1.45
3rd Gear ..............................1.......... 1......... 1
4th Gear .........................0.69...... 0.69.... 0.69
R Gear ............................2.21...... 2.21.....2.21
Torque Converter Diameter 273mm 273mm 310 mm
Input Torque (ft lbs).......... NA ........NA ......450
GCVW (lb) ......................7800 .....14000 ..19000
Application........................ V6 .....4WD,V8... V10
Old Apr 28, 2019 | 04:06 PM
Pete Lambright's Avatar
Pete Lambright
Question Pete
I have a 1998 Dakota Sport two drive regular cab with a 3.9 and the automatic transmission. The code plate in the glove box has two codes, DGB and DGK 4 speed automatic transmission. What do these codes mean? Thanks for your time and help.
Old Apr 28, 2019 | 08:01 PM
mmerlinn's Avatar
mmerlinn
Hijacking a dead thread is likely to get you ignored.
To get the BEST and FASTEST answers to your QUESTIONS, ALWAYS start a NEW thread when your post will not ANSWER the OP's question.
Old Apr 28, 2019 | 08:58 PM
Not to mention you really want to be in the 2nd gen dakota section......
Old Apr 28, 2019 | 09:01 PM
Pete Lambright
Default Pete
Sorry didn't mean to intrude.
Old Apr 29, 2019 | 07:30 AM
You did not intrude. You searched the internet and it brought you here. No worries.
Old Dec 26, 2019 | 08:25 PM
Charles Edwards Jenkins Jr.'s Avatar
Default I have a 2003 Dodge ram 3500 with a 5-speed manual how can I tell which transmission
Okay guys I have a 2003 Dodge ram 3500 5.9 Cummins with a 5-speed manual transmission, how can I tell which transmission is in it
Old Dec 27, 2019 | 12:52 AM
mmerlinn's Avatar
mmerlinn
How does this answer the OP's question which he posted nine years ago? Further, why would anyone come to this thread looking to answer a question UNRELATED to the thread posted thereon?
To get the BEST and most accurate answers ALWAYS start a NEW thread whenever you have a question. NEVER HIJACK another thread else you may NEVER get an answer.
