installed my 180 thermostat and now theres a gas smell
Old Oct 2, 2010 | 11:29 AM
yellowbeast's Avatar
yellowbeast
Default installed my 180 thermostat and now theres a gas smell
I put in a 180 thermostat and now after I let off the gas there's a strong gas smell granted the exhaust ends under the cab but before the install there wasn't the smell any ideas?
Old Oct 2, 2010 | 11:52 AM
Reset the PCM. Drive it for a few days. See what happens.
And make sure there aren't any leaks....
Old Oct 2, 2010 | 12:07 PM
yellowbeast
Ok so detatch negative terminal for a few minutes reconnect and drive and that should help?
Old Oct 2, 2010 | 12:11 PM
If it is just because it is running rich.... then, probably. if it doesn't, need to figger out why.
Old Oct 2, 2010 | 12:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
After disconnecting the neg battery cable, turn the headlights on for a minute or so. Turn lights off and reconnect battery cable. BTW, a 180 stat will make it run more rich and get worse mpg's. Not worth it IMHO.
Old Oct 2, 2010 | 12:29 PM
yellowbeast
The reason I installed it is I eventually want a tuner and tow a trailer which mad my truck run warm
Old Oct 2, 2010 | 03:04 PM
zman17's Avatar
zman17
Either one of those does NOT make it a requirement to install a 180 stat! If you are running hot when towing, you have another problem.
Old Oct 2, 2010 | 04:16 PM
UnregisteredUser's Avatar
UnregisteredUser
Running hot when towing? Be darn sure to look at the automatic transmission as a potential culprit.
Old Oct 2, 2010 | 08:28 PM
littletunny's Avatar
littletunny
Yeah I never understood the 180 tstat. If the designers of the engine wanted it to run @ 180 they would have made it that way. Engineers spend hundreds of hours designing these motors to run at a certain temps.
Old Oct 2, 2010 | 09:43 PM
atlrus's Avatar
atlrus
We are talking about Chrysler engeneers in the 90's, not exactly the brightest minds in the auto industry... And following your train of thought, you don't understand any aftermarket part then?!?
If the guy plans on doing some heavy towing it's much better to sacrifice 0.1 MPG in daily driving for the 10 degrees of cooler engine, which would extend the life of all components in the long run.
To the OP - running 180* thermostat will NOT make your fuel so rich that you can smell it from the exhaust. If this was true, we should be seeing gasoline oozing out of the pipes every time we start a cold engine...Trace back your steps of installing the thermostat and see if you missed something or did something wrong.
P.S. They also make 170* thermostats
