NP231, np231HD, or WHAT??????
Old Oct 8, 2010 | 04:05 AM
crawlin95's Avatar
crawlin95
the only difference between the 231d and 231hd is the hd has a six pin planetary if your going to upgrade then go to a 241 out of a 2500 at least almost everything on the 241 is alot stronger including the case. the 231 was originally built for the jeep yj and thats pretty much all they are good for the 231 wasnt originally intended to set behind a v8 trying to lug around 6500 lbs. dont get me wrong the 231 can be built nearly bullet proof and there is even a company that builds stronger cases for them but it just makes more since to get a tcase that was originally built to withstand the load.
Old Mar 1, 2011 | 07:30 PM
Norm Mayer's Avatar
Norm Mayer
I have a 99 dodge ram with a 231hd transfer case. I need to find parts for it, i need the bushing on the rear tailhousing but i believe its pressed in, can anyone tell me any pointers?
Old Mar 1, 2011 | 08:13 PM
Brass bushing? You can slice it in a couple spots with a hacksaw blade, (be careful....) and take it out in pieces. There are rebuild kits that come with EVERYTHING for like 150 bucks. I think bushings are included.
Old Mar 2, 2011 | 12:34 PM
Norm Mayer's Avatar
Norm Mayer
its not a brass bushing, its a steel one. Its in the tailhousing of the transfer case. It worked its way out when I was driving down the road and i put it back in with a piece of 2x4 but it worked its way back out again. Is it pressed in?
Old Mar 2, 2011 | 12:37 PM
Norm Mayer's Avatar
Norm Mayer
Its the extenstion bushing in the rear housing extention on the transfer case. I need to know if I can but the tailhousing with the bushing already pressed in, im tryin to avoid taking the truck to dodge
Old Mar 2, 2011 | 12:44 PM
The bushing doesn't wanna stay in? Not good..... Is it binding on the slip yoke?
Should just be pressed in..... replacing the entire tailshaft might be a good plan.
Old Mar 3, 2011 | 01:43 AM
crawlin95's Avatar
crawlin95
what year is your truck and where are you located if you close to texas i have one you can have.
Old Mar 3, 2011 | 01:44 AM
crawlin95's Avatar
crawlin95
the whole tail houseing off a truck that had 30k for free it's just taking up room in my shop.
Old Mar 3, 2011 | 01:09 PM
Norm Mayer's Avatar
Norm Mayer
i have a 99 dodge... bay city tx
Old Mar 4, 2011 | 01:03 AM
crawlin95's Avatar
crawlin95
I'm located in weatherford 30 min west of fort worth not sure where bay city is if you want this tail housing you can have it it is off a 2000 dodge ram they wont fit on my truck because it is a 95. I also have the output shaft as well if you want it.
