High Octane
Old Oct 6, 2010 | 08:44 PM
imjammin's Avatar
imjammin
Default High Octane
I have a 94 1500 5.2 and have to run high octane to keep the motor from ratteling. What would be a good solution or is there one?
Old Oct 6, 2010 | 08:47 PM
Salex007's Avatar
Salex007
do a tune up
Old Oct 6, 2010 | 08:54 PM
imjammin's Avatar
imjammin
Done that. I've had the truck for 6 yrs. always been this way.
Old Oct 6, 2010 | 08:55 PM
UnregisteredUser's Avatar
UnregisteredUser
Figure out why! Are you having to add oil between changes? Do you maybe have a vacuum leak? Is it overheating, or getting close to it?
Need. Input.
Old Oct 6, 2010 | 09:00 PM
dhvaughan's Avatar
dhvaughan
fix the leaking plenum and replace the timing chain (and water pump while you are there).
Old Oct 6, 2010 | 09:04 PM
imjammin's Avatar
imjammin
Need. Input.
I do add oil, but it has 251,000 on it. Pretty sure no vaccum leak, temp is fine.
Old Oct 6, 2010 | 09:05 PM
imjammin's Avatar
imjammin
All of the above have been done.
Old Oct 6, 2010 | 09:12 PM
Hahns5.2's Avatar
Hahns5.2
Seafoam it and remove the carbon build up, completely eliminated the pinging in a friend's Ranger...
Old Oct 6, 2010 | 09:16 PM
lastrights's Avatar
lastrights
you may have a cracked head ? these motors are known for that also
Old Oct 7, 2010 | 01:33 AM
jasonw's Avatar
jasonw
Site Moderator
Have you ever changed the oxygen sensor? How long ago did you "fix" the plenum, and did you just change the gasket or did you perform the Hughes or APS type fix?
