Transmission Rebuild Checklist
Old Oct 11, 2010 | 02:18 PM
superdudedwk's Avatar
superdudedwk
Default Transmission Rebuild Checklist
Im Gearing up for a complete rebuild, (and upgrade) of my 46RE so I just want to make sure I am getting everything I need
I Have a 96 Dakota (I know wrong forum but you guys are the ones to ask for a 46RE question) 4x4 5.2L with 114,000 and a 46RE and the reverse went out not too long ago. I have been looking into rebuilding and I decided I would do a full rebuild; clutches, bands, etc... I also want to install the Sonnax Sure Cure kit, install an auxillary cooler, install a temp sensor, and a dodge to GM governor solenoid change.
Before I do I want to know A) Is there anything else you guys would recommend doing while its out? B) what rebuild kit do you guys recommend? C) what torque converter do you guys recommend?
Oh and if it makes a difference I am planning on swapping out the 5.2L for a rebuild and slightly improved 5.9L soon. Any links or advice is greatly appreciated, I wouldnt know half of what I know now without you guys on this forum. THANKS!
Old Oct 11, 2010 | 03:07 PM
Look on page six of MonteC's trans thread, there, you will find a list of parts that were recommended for a member that was rebuilding his trans. Bear in mind though, that he was regularly towing a 7000 pound trailer, so, there are some of the 'upgrade' parts that you wont really need. (the hard parts. extra clutches and such are a very good idea.) If you go by that list, and get everything on it..... I think you would be hard pressed to break your trans.
Old Oct 12, 2010 | 09:03 AM
superdudedwk
Awesome Thanks!
