automatic to manual
Old Oct 11, 2010 | 06:21 PM
jsmith155's Avatar
jsmith155
Default automatic to manual
i just bought a parts truck an it happens to be a 318 5 speed well my truck is a 360 automatic is it possible to make the conversion? is it hard? will the truck run right?
Old Oct 11, 2010 | 06:31 PM
Grab the PCM, harness, and sensors from the manual truck, and, of course, all the manual trans stuff..... put it on your truck. If they are both the same year, should work fine, though you will have to reflash the PCM for the correct engine size. If you have 4wal, you may also run into problems with a VIN mismatch between the PCM, and the abs controller. (not sure if that is an issue with RWAL)
If the years are too far different, (like, if the donor is 97 or older..) it will be MUCH more interesting, as some of the dash wiring is going to be different.
Old Oct 11, 2010 | 07:35 PM
jsmith155's Avatar
jsmith155
well my truck is an 98 an the donor is a 96 an could you explain that agin in dumb person words
Old Oct 11, 2010 | 08:08 PM
there are some pretty serious differences between the 96, and the 98.... you wont have everything you need to complete the swap out of those two trucks. The dash wiring is different, the instrument cluster is different, the speed sensors got mucked about with, (maybe). You would still need to get the wiring harness, and PCM from a 98 truck, with a manual trans to make the swap 'easy'...... as it stands, you would be spending more time trying to chase down wiring demons than it would be worth, at least, to me.
Old Oct 11, 2010 | 08:19 PM
jsmith155's Avatar
jsmith155
yea i had a feeling about that i can get a computer for my truck pretty easy i may have to look around for the harness is there any other wiring that needs done anything other then the tranni swing pedals etc that i can use im hellbent an bound on doin this
Old Oct 11, 2010 | 08:24 PM
Might be easier just to fix whatever is wrong with the truck that already has the manual.... certainly cheaper.
And it isn't something I have actually done before, at least, not on a 2nd gen dodge..... so, I am not speaking from direct experience, just from what I know of these trucks, and the numerous changes dodge seemed to think were such a great idea, from year to year.
No matter which way you shake it, there are going to be bits and bobs that you will have to chase down.... and they might be fun to find. Just getting everything installed is only the first battle, then, you have to convince it all to WORK.......
Old Oct 11, 2010 | 08:39 PM
jsmith155's Avatar
jsmith155
haha i wish i could use that truck but idk id love to find someone who has done this jus to get an idea of wat they had to do
Old Oct 12, 2010 | 11:30 AM
rideordie's Avatar
rideordie
Heyyou is probably right. It's probably not worth the hassle to change it all out.
If you're really interested, do some searching on the forums you'll find all kinds of stuff to read. It's not impossible, but probably not worth while.
Old Oct 12, 2010 | 11:38 AM
dodgeram07's Avatar
dodgeram07
there was a guy on this did a trans swap........ try seaching i would but i can every find anything
