Front axle shaft bearing & race question...
I am new to the forum, so go easy on me. I have a 1996 dodge ram ext cab 4x4 auto 5.9l gas. I have a driver side axle seal that is leaking, so we went into it and we took the bearing race off of both sides where the 3rd member is....The one on driver side has a black place on it where it looks like it might have spun it or been riding more on that part or something. The other side looks shiny. My question is should this race be replaced or is this normal?
Ideas and comments greatly appreciated....
thanks
kenneth
thanks
kenneth
The bearing caps only hold the race in place. The race does not move on the cap. At least, its not supposed to........
Also, I am not sure that you can just go out and buy a new cap, and install it, and expect it to solve the problem. I would suspect that it will simply generate a new problem...... Reassemble your diff, with the original parts, in their original positions, and torque them to spec. Keep the fluid level up, and you should be ok.
Just my op but replace both caps and the bearings. With the carrier assy out I would bolt on the old caps and torque to spec then get a bore micrometer and check the holes for out of round,then do the same with the new ones and compare.The bearing races should not be turning in the caps. I would be going though every part of that carrier assy very carefully looking for hot spots and bearing chatter marks. By adding new parts you will need to reset your gear lash back to the proper pattern.You can get the caps from most trany and diff shops along with the bearings.
On the other hand you can probably put it back together and never have a issue but you never know.
