Continued LED Modifications...
Old Oct 16, 2010 | 06:02 PM
EndIsNear's Avatar
EndIsNear
Default Continued LED Modifications...
Well, if anybody remembers, I created the LED Dash DIY that swapped the existing bulbs in the dash cluster, climate controls, cubby hole with blue LED's. I mentioned that I fried my door lock/window control in my passenger door trying to mod them with blue LED's to match. Well after that failed attempt so long ago, I tried again today, with better luck . This time I did the driver side window/lock controls, and they turned out great. I also, a few months ago, swapped my dome lights with white LED's. They are very bright and look awesome. I'll take some pictures when it gets a little dark outside and post them here later. Just thought I'd share...
Old Oct 16, 2010 | 06:48 PM
EndIsNear's Avatar
EndIsNear
Here's some "work in progress" pictures.
Old Oct 16, 2010 | 06:59 PM
BigRedRam95's Avatar
BigRedRam95
I wish my switches lit up. I got the cluster done I just need to do the a/c and heat controls. Thanks for the idea
Old Oct 16, 2010 | 10:44 PM
BlueBeast2's Avatar
BlueBeast2
Awesome. Do you have fogs? If so did you change the fog indicator light on your headlight switch?
Old Oct 17, 2010 | 01:56 AM
EndIsNear's Avatar
EndIsNear
Thanks for the replies. Unfortunantly, no I don't have fogs. not sure how the wiring would be for that. Here's some pictures I promised.
My dome lights...
Old Oct 17, 2010 | 02:23 AM
DodgeTheFather Ramthe Daughter's Avatar
looks great really customized the truck
Old Oct 17, 2010 | 02:30 AM
BlueBeast2's Avatar
BlueBeast2
why you gotta give me more ideas? Looks good, I assume beings you fried the first set it's not easy to do?
The fog wiring ain't an issue it's what led to use. It's super tiny
Old Oct 17, 2010 | 08:31 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
My dome lights...
That totally rawks. How'd you do the lights on the door controls?
Old Oct 17, 2010 | 10:30 AM
EndIsNear's Avatar
EndIsNear
You might have to mod one to make it work.
Doing the door switch isn't necessarily hard, it's just...tedious. You have to solder them on, and my first soldering guns tip was huge and bulky, and some of my solder would run, which leads me to believe i might have caused two connections to touch and burned them up. So I bought a new gun with a really pointed tip, heated up the existing bulbs solder, pulled them out, and put in my new blue ones. The process isn't hard, like I said, just have to make sure everything is done right. On the driver side, you'll notice in my previous pictures that I had to run one on a wire. Because that one LED is so tiny, I couldn't reach it, nor did I have a blue LED to fit, so I routed a different one. When I get a new passenger side switch, I might try and do a DIY just for the hell of it.
Old Oct 17, 2010 | 02:06 PM
Andrew2500's Avatar
Andrew2500
Looks awesome!
