47re transmission Problem
Old Oct 17, 2010 | 11:08 AM
T-rev's Avatar
T-rev
Default 47re transmission Problem
I have 1998 dodge 2500 v10 4x4 with the 47re transmission. I pull a travel trailer (10,000 lbs.) and a few weeks ago I blew a transmission line while pulling the trailer i got it off the road quickly (less than a 1/4 mile down hill)and got it fixed. I drove the 3hr trip home and no problems it worked flawsly . The fluid level is fine and no burnt smell. I drove it again and now here and there when its cold i have no second gear. If move the trans. to neutral and let it set and pump it works fine. could something be pluged or of gotten dirt in something? After letting it set in neutral it will work fine no sliping, no eradic shifts , even pulling a load its fine.It has only done this twice. Its crazy. Please help Thanks
Old Oct 17, 2010 | 11:17 AM
Possibly a solenoid giving up? Governor pressure sensor/solenoid?
Probably posting in montec's trans thread would be a good idea.
Old Oct 17, 2010 | 11:23 AM
95RAM360's Avatar
95RAM360
check valve? not sure if the 47re's have it as well./...
Old Oct 17, 2010 | 11:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
idea.
+1 on the Gov sensor/ solenoid.
Old Oct 18, 2010 | 06:03 AM
T-rev's Avatar
T-rev
Thanks guys, I will try the govoner/ solinode.
Old Jul 18, 2016 | 11:03 PM
sminclover's Avatar
sminclover
Default 1998 ram 2500 tranny acting up
Transmission slipping when truck is going down the road, around 40 mph. like jumping in and out of 2nd and 3rd gear, changed fluid last oil change, checked level and its good, has anyone had this problem, or any ideas,
thanks scott
