How To Clean The Plenum?
Old 10-19-2010, 10:51 AM
lennemann23's Avatar
lennemann23
lennemann23 is offline
Default How To Clean The Plenum?
So I took my plenum off because my gasket was blown. My hughes kit will be here Thursday. In the mean time what do I use to clean off the old gasket material? Brass wire brush? Also what do I need to do to clean the oil off the plenum inside and out?
Old 10-19-2010, 11:43 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Use a razor blade and scrap off the old gasket material. Take the plenum to a shop that rebuilds heads or maybe a radiator shop and ask if they'll steam it. Chances are, they'll do it for a couple of bucks and it'll come out looking great.
Old 10-19-2010, 11:48 AM
lennemann23
No one in my town will do that. I can pressure wash it? Also can I use a brass wire brush to clean up the gasket surface? Dude your in Norman? I'm in Grove. 4 Hours away lol.
Old 10-19-2010, 12:47 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
Yes, you can pressure wash it. Soaking it with a good degreaser first will help. And yes, a brass brush will be fine with cleaning the gasket surface.
Old 10-19-2010, 12:52 PM
lennemann23
Okay will do. Also to the right of the thermostat housing there is a sensor. What is that sensor called? It broke when removing the plug. It's to the right of the thermostat housing looking at the front of the engine.
Old 10-19-2010, 12:57 PM
drewactual's Avatar
drewactual
drewactual is offline
degreaser and a pressure washer works... I started mine out like that.. I wasn't happy with the results, so I made a nice paste with laundry detergent and water and smeared it all over it with heavy concentration on the nasty spots- and put that biyatch in the dish washer when nobody was watching (the keg, not the biyatch)... it came out looking anew... well, almost anew...
I also got some alcohol for the gasket cleaning... don't waste the good stuff (Beam, Daniels, or even SkyBlue) use the stuff that comes in a can from the paint department of your local hardware store... the gasket surface on the heads, the intake, and the cross-block were perfect when I put it all back together... they didn't stay that way long, but that is another story..
anyway, it's hard to hurt that thing... hit it with whatever you would any metal material you want clean but wouldn't want to destroy... you may find razor blades near the ports beneficial too- but be somewhat careful not to gouge..
good luck!
Old 10-19-2010, 02:09 PM
lennemann23
Should I remove the fuel inj. before I spray the plenum with degreaser?
Old 10-19-2010, 02:19 PM
drewactual's Avatar
drewactual
dude, if you're going to clean that thing proper the fuel rail along with the injectors and everything else need to be stripped off.. the only thing on mine when I did it was the alternator brace arm, which served as a nice handle at times...
make sure you don't leave one of the fuel injector o-rings in it when you pull them all..
personally, there is no way I would allow anything even mildly corrosive to come near my injectors... I'd pull those rascals and put em' in a baggie... I just left my fuel rail in the engine compartment w/ injectors still attached... you really don't want to dry out the rings, and you don't want them lost... it makes all kinds of sense to polish the bosses while you have that thing apart anyway..
Old 10-19-2010, 02:59 PM
Gary-L's Avatar
Gary-L
Gary-L is offline
While you're at it, replace the injector O-rings. It's cheap insurance against an engine fire due to torn rings. Take care to install the new ones after having lubricated them with a bit of clean oil.
Old 10-19-2010, 03:22 PM
lennemann23
Yeah I figured I would do that. Also, what can I use to get the rest of the oil and dirt off the plenum? And can I use a wire wheel (not brass) to remove the old pieces of gasket that is left on the plenum anywhere?
Quick Reply: How To Clean The Plenum?
