14x3 round air cleaner
Old Oct 20, 2010 | 08:55 AM
rudy98's Avatar
rudy98
Default 14x3 round air cleaner
I know someone else probably has this posting out there but besides the air cleaner itself what spacer do i need? anything to seal it on to the throttle body? also do i need an S bolt? i read that i do need one so what size would i need? Basically what do i need to successfully put this air cleaner on my truck. Thanks guys
Old Oct 20, 2010 | 10:52 AM
RM_Indy's Avatar
RM_Indy
I have a 1/2" drop base when I use my 14x3" K&N filter.
Always use a gasket ontop of the tb.
Must use an S bolt
Heard of others using a 1/2" spacer under a 1" drop base.
Old Oct 20, 2010 | 05:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have a 5 speed , so it might not be as noticeable, but with a stock motor, you will lose some bottom end. But, if you have your heart set on it, here you go. https://dodgeforum.com/forum/2nd-gen...-assembly.html
Old Oct 21, 2010 | 01:40 PM
rudy98's Avatar
rudy98
what is the best way to bend that rod?
Old Oct 21, 2010 | 02:30 PM
slider15004x4's Avatar
slider15004x4
The s bolt I bent was 4.5" long with a 3/4" offset. I used a bench vise to bend mine. I am either going back to stock or going to a CAI because I noticed the difference in my bottom end power.
Old Oct 22, 2010 | 08:47 AM
rudy98's Avatar
rudy98
Thanks, and yeah i noticed the diff in my bottom end power too but as of right now im not towing anything heavy so i should be fine.
Old Oct 22, 2010 | 12:32 PM
RM_Indy's Avatar
RM_Indy
Are you guys that have lost some bottom end using a K&N 14x3"(E1650) or another filter?
Old Oct 22, 2010 | 12:38 PM
slider15004x4
I'm using the Eldebrock filter that came with the 14x3.
Old Oct 22, 2010 | 05:38 PM
zman17's Avatar
zman17
When I put the 14x3 on my 98, I used a K&N and a Wix, and the one it came with. I lost bottom end with all 3 filters. That, and along with the fact, I couldn't stand the sucking noise, is why I ditched it.
Old Oct 22, 2010 | 07:07 PM
Hahns5.2's Avatar
Hahns5.2
I'm confused how higher flowing filter reduces bottom end other than the fact I suppose it's sucking in hotter air at low speeds.
