Steering stabilizer
Old Oct 21, 2010 | 10:08 PM
slider15004x4's Avatar
slider15004x4
Question Steering stabilizer
I am purchasing a 3" suspension lift, should I replace the steering stabilizer at the same time? Also should I upgrade to the dual stabilizer kit? This is my first truck so I am unsure of what exactly the advantage of them is or why they are needed. Thanks.
Old Oct 22, 2010 | 07:45 PM
mopartimmy's Avatar
mopartimmy
Nice Truck! it would probably be a good idea to change the shock out. As for going to a duel most of the time 35's and larger its a good time to switch to duels.
Old Oct 22, 2010 | 07:55 PM
slider15004x4
Thank you. I just ordered the dual stabilizer just to be safe. It's a work in progress. I've only had it for 2 months.
Old Oct 30, 2010 | 11:50 AM
dodgeman52's Avatar
dodgeman52
when installing the dual stazilier do u take off the factory one and leave it off?
Old Oct 30, 2010 | 06:55 PM
Yep. Toss the original. Or, add it to the scrap metal pile.
Old Oct 31, 2010 | 09:40 AM
dodgeman52's Avatar
dodgeman52
http://www.topguncustomz.com/Store/G...iview=25474266 i was lookin at that one and what changed in 2000 for it not to fit without a 3 inch or higher lift?
Old Oct 31, 2010 | 09:55 AM
TheBigRedOne's Avatar
TheBigRedOne
You really don't need one at all. My race truck, and most of the trucks I've built have never needed them.
Old Oct 31, 2010 | 05:21 PM
dodgeman52's Avatar
dodgeman52
any ideas?
Old Nov 1, 2010 | 12:07 AM
northernRAM's Avatar
northernRAM
i run 38 bias plys and for the first while i just bought the skyjacker it that just bolts into the factory position, it worked just fine and got rid of that wick death wobble. Since then i have just ripped that mounting bracket off the frame and built a drop bracket for it, while still running just a single shock, it works great. So as long as your factory shock isnt blown, dont waste your money
Old Nov 1, 2010 | 03:11 PM
dodgeman52's Avatar
dodgeman52
well idk if it blown but would like to upgrade it
