hello all
Old Oct 24, 2010 | 12:04 AM
ostrx250's Avatar
ostrx250
Default hello all
hello guys and gals
got a neighbor 97 ram1500 front drive shaft i can turn by hand while truck is sitting on the ground i belive front pinion or ring are gone anyone with info on this ?? or a online manual ???
Old Oct 24, 2010 | 09:44 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Oct 24, 2010 | 10:06 AM
There is a manual available in the FAQ section.
If the truck is NOT in four wheel drive, you should be able to turn the front driveshaft, even with the truck in park, and the front wheels on the ground.
Old Oct 24, 2010 | 12:02 PM
dhvaughan's Avatar
dhvaughan
greetings. as said when in 2wd, drive shaft is disonnected at two points. in the t-case and also at the passenger side axle disconnect (CAD). so combined with the diff's spider gears, everything rotates freely.
if you crank the truck and shift to 4wd, and the vacuum operated CAD actually works and connects the axle halves, then you get a different result.
when the CAD doesn't work, begin troubleshooting here
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Oct 24, 2010 | 12:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is there some related problem you are having? Let us know.
Old Oct 24, 2010 | 12:31 PM
ostrx250's Avatar
ostrx250
ok i was wonder owner clams someone told him he need a new ujoint but he lost an iac and was unable to restart so i just took a look diagnosed the running prob and when i was lookin at everything i turned the shaft and wasnt familiar with the interworkings of the front drive turns really easy i will have to investigate a bit more he complained of popping and 4by4 not working good thankyou for the fast responses
Old Oct 24, 2010 | 12:39 PM
dhvaughan's Avatar
dhvaughan
popping is likely an axle u-joint. its very easy to check while its sitting still. just rotate axle side back and forth against the wheel side. it'll probably go clack clack.
vacuum cad malfunction happens to them all. it's usually a vacuum problem with rotted off or torn off vac lines.
caution, working on one of these trucks is a full time job. LOL
Old Oct 24, 2010 | 02:25 PM
dhvaughan's Avatar
dhvaughan
don't be afraid to end one sentence and start another. its not against the rules. LOL.
Old Oct 24, 2010 | 08:23 PM
ostrx250's Avatar
ostrx250
hahaha ill try to watch my run on sentences thanks for the info again people
