My "Rock Solid" Ram Steering Upgrade Experience
Old Jan 3, 2021 | 05:09 PM
  #91
Toby Hammett's Avatar
Toby Hammett
Don't forget (like I did....) the little wire that goes from the column, to the PRNDL in the instrument cluster.........
Aside from that, I think ya got it.
Okay so I'm back at it after the holidays and those top two black/star nut looking things holding the middle of the column are interesting as I'm having a hard time getting a good fit with any socket - 3/8 too small, 7/16 too big, 10mm fits but then rounds it...
Anyway, my larger question is where do I disconnect the entire wiring loom at? I've disconnected the black plastic piece in the middle that holds it to the steering column but if I go to pull out the steering column the wiring loom appears to still be attached, not seeing how I can remove the harness from one end or the other from what I see here? Thanks
Old Jan 3, 2021 | 07:56 PM
  #92
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Remove the plastic surrounding the column and unplug then from there switches
Old Jan 3, 2021 | 10:12 PM
  #93
Toby Hammett
Many thanks MoparFanatic - I've got the three bolts at the bottom and two bolts midway up out/loose so thanks for that last bit of advice
Old Jan 9, 2021 | 03:08 PM
  #94
Toby Hammett
Okay so I have removed cough, broke some of the plastic surround on the steering wheel to access some of the plugs I need to disconnect in order to remove the steering column from the truck - well there is an additional 5 wires that appear to have no connector and end into a box below the ignition. Super frustrating at this point as it doesnt appear they just pull out - any thoughts? Much appreciated -
These are the 5 wires that go from the large wiring loom attached to the column and seem end here, below the ignition.
This is a look from the key side, you can see that black box where the wires enter doesnt look like something I need to be taring into...ugh
Old Jan 9, 2021 | 06:51 PM
  #95
MoparFanatic21
It unplugs if memory serves right there are two tabs on the side
