uneven tire wear
Old Nov 8, 2010 | 10:00 PM
BigRedRam95's Avatar
BigRedRam95
Default uneven tire wear
My truck has had 2 front end aliments in the last two mounts and is going for another on 11/11/10. I am having uneven wear on the outside edge of the pass side front tire. I have a shake at 70-80MPH. I has 4 new ball joints and two new axle u-joints. I know it needs new shocks but would that cause this? What about the axle/hub bearing? What would cause this?
EDIT: I jacked up the truck today and took a pipe and put it under the tire and pry-ed up to see if there was any play in the hub and no movement
I think I am going to buy a set of rough country nitro 9000 shocks tommrow
Old Nov 8, 2010 | 10:12 PM
99dodge318's Avatar
99dodge318
a slight shake at 80 mph on a solid axle 4x4 truck is not bad at all! mine shakes violently at 65 mph on certain roads. but rides straight and smooth on others.
Old Nov 8, 2010 | 10:17 PM
BigRedRam95
oh it shakes violently.
Old Nov 9, 2010 | 08:15 PM
BigRedRam95
Bump!!!!
Old Nov 9, 2010 | 10:12 PM
audiomechanic's Avatar
audiomechanic
When you had the truck in the air to check for wheel bearing play, did you also spin the wheel and listen carefully to the bearing. It should sound very smooth.
How old are the bearings?
Old Nov 9, 2010 | 10:18 PM
BigRedRam95
I did spin it no noise it sounds good. They are the bearings that came on it from the factory 81,000 on it.
Old Nov 9, 2010 | 10:23 PM
audiomechanic
Can you take a pic of the uneven wear and post it up?
Old Nov 9, 2010 | 10:25 PM
BigRedRam95
Yes I will but It will have to be tomorrow when I can borrow a camera.
Old Nov 9, 2010 | 10:58 PM
audiomechanic
I just figure it would help the guys on here see what exactly the problem is and help source it.
Thanks for indulging us.
Old Nov 9, 2010 | 11:54 PM
How often do you rotate your tires?
