torque converter going out?
Old Nov 10, 2010 | 07:40 PM
thompson1986's Avatar
thompson1986
Default torque converter going out?
in the past few days my truck has started acting up, it seems like its having a hard time shifting gears there is some tranny fluid around the trans pan, but my fluid level seems to be fine it shows as full
it sometimes stutters at idle when in gear
when im going about 45 it puts around lowers and raises RPM
shifting between 1st and second gear seems to be giving it prolems.
any suggestions?
Old Nov 11, 2010 | 08:53 AM
What year truck? Engine?? 2 or 4 wheel drive? Mileage?
Old Nov 12, 2010 | 09:23 PM
thompson1986
97 5.2V8 4 wheel drive with 176k
Old Nov 12, 2010 | 11:51 PM
95RAM360's Avatar
95RAM360
when you checked the fluid you did make sure it was in neutral while running right?
checking in park will NOT give you an accurate reading.
Old Nov 13, 2010 | 01:27 AM
BackwoodsRam's Avatar
BackwoodsRam
sounds like ur trannys goin out, mine was doin the same thing at 155k and i had to get a new tranny before i even hit 156k
Old Nov 13, 2010 | 07:09 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Not sure if it will work on a 97, but give this a shot and see if any codes come up. https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Nov 13, 2010 | 07:57 AM
thompson1986
so to make myself sound like a total moron here, i checked and inspected everything. its all fine in the trans department, turns out alot of my cylinders were misfiring and to me it felt like like the torque converter was going out like it did on my ford, screwed around some more found no cause for these lovely misfires i suddenly had, checked at the gas station for fuel truck times because odly enough it all began happening right after i bought a tank of gas...so they refuled about 2 minutes before i showed up and i am just going to assume the gasoline i have is not the greatest in the world right now a few local mechanics seem to agree with me on it as well
Old Nov 13, 2010 | 07:58 AM
zman17's Avatar
zman17
Get some Techron + fuel additive, and see if that helps any.
