Jasper replacement rear axle?
Old Nov 12, 2010 | 05:07 PM
dugluvzsher's Avatar
dugluvzsher
Default Jasper replacement rear axle?
I have a 2001 extended cab ram 4X4 with a bad rear differential. I found someone parting out another ram, he said it has a jasper rear from the previous owner. I am looking for opinions on which is better a Dodge or a Jasper
Old Nov 12, 2010 | 11:07 PM
jasonw's Avatar
jasonw
Site Moderator
I moved this to the 2nd generation section (1994-2001), get you some help.
Welcome to DF.
Old Nov 12, 2010 | 11:30 PM
95RAM360's Avatar
95RAM360
IMHO, since you have to replace the rear end....id just get a complete D60 or 70 rear end, way more durable than the Chrysler 9.25 rear end. and from hearing stories of Jasper trannys, i wouldnt trust it. Ive heard MANY bad things about the Jasper trannys, so i wouldnt trust anything from Jasper.
Old Nov 13, 2010 | 06:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The Jasper is a Dodge rear end, it's just rebuilt by Jasper. It will be a direct swap. Putting a D60 in will not be a direct swap.
BTW, it would be nice to know if you have a 1500 or 2500.
Old Nov 13, 2010 | 07:38 AM
dugluvzsher
Thanks for moving me and it's a 1500.
Old Nov 13, 2010 | 07:49 AM
zman17's Avatar
zman17
Make sure it has the same gears also.
Old Nov 13, 2010 | 08:49 AM
dhvaughan's Avatar
dhvaughan
welcome to df. fill out your signature and location stuff when you get a chance.
i guess its possible that it has a jasper rear end, but i doubt it. reason being is that unlike a ford or toyota where anybody can buy and installed an already setup ring/pinion, the dodge and dana has to be setup in the axle. this would imply that they bought a complete axle assy from jasper. possible but unlikely. most shops would just rebuild the failure, or get a junkyard replacement. more likely is that he has a jasper transmission and is just confused.
complete rear ends are pretty common in junkyards for around 300-350 or less.
+1 on what zman said - since yours is 4wd, make sure the gear ratio is the same as yours.
Old Nov 13, 2010 | 08:57 AM
zman17's Avatar
zman17
For your reading pleasure, http://www.jasperengines.com/differentials.php
Old Nov 13, 2010 | 09:09 AM
dhvaughan's Avatar
dhvaughan
damn
edit - according to that web site, a 9.25 is $2119 + 50 for a skid.
i'm not sure if that includes installation or not.
that's a damned expensive rear end.
Old Nov 13, 2010 | 09:18 AM
zman17's Avatar
zman17
Originally Posted by dhvaughan
damn
Just for that, come over and install the crank sensor, so I can move that junk around my yard when I need to. LOL
