Help please, sucking and bad idle...
Old Nov 12, 2010 | 11:02 PM
killacoon1's Avatar
killacoon1
Default Help please, sucking and bad idle...
its a 97 ram 360 90000 miles when i first start my truck after about 20 -30 secs i get ths loud suckin noise from the moter and it starts to idle bad like it wants to shut down you can also smell fumes some times. after the truck gets hot it will idle fine have no clue what this could be .. all help appreciated.. thanks
Old Nov 13, 2010 | 04:01 AM
ramboy99's Avatar
ramboy99
the only 2 things i can think of off hand is either gonna be a problem with the throttle body or a vac line somewhere
Old Nov 13, 2010 | 05:34 AM
UnregisteredUser's Avatar
UnregisteredUser
That's the upstream oxygen sensor. Just replace it and get happy.
Old Nov 13, 2010 | 08:04 AM
pcfixerpro's Avatar
pcfixerpro
Most likely not the o2 if it is when he first starts up. It would be in open loop. The IAC motor is making the whistle noise, but my truck whistles for a little bit too on a cold start. That said, two of my friends IAC motors whistle all the time. As far as the die'n (you say wanting to shut down)... do the rpms drop, truck shakes, and then revs a little to compensate?
Old Nov 13, 2010 | 02:12 PM
killacoon1's Avatar
killacoon1
well it wont rev it self at all it just shakes and the sucking noise is alot louder than usual once i give it gas it idles fine for a min then starts again until i drive it
Old Nov 13, 2010 | 02:50 PM
Tough Ram's Avatar
Tough Ram
Mine did that to me also and come to find out it was the EGR valve. Check that and see if it is bad. It wont throw any warning lights or anything at least mine didnt. They are like $90 at autozone.
Old Nov 13, 2010 | 03:19 PM
Pull the front O2 sensor out of the exhaust, and try again. If it runs better... replace or remove the cat.
Old Nov 14, 2010 | 12:37 AM
killacoon1's Avatar
killacoon1
ok how do you check the egr and do you mean the o2 that runs into the cat thanks all...
Old Nov 14, 2010 | 04:38 AM
UnregisteredUser
Yep, the sensor that's essentially in the upstream side of the cat is the one you want. If it's not been replaced already, it's time to do it because they tend to fail right around 100,000 miles or so. And since it's about that time for a periodic maintenance replacement, I recommend doing it straight away. If (I'd say when) it fixes the problem then you can just be happy and not worry about the other potential culprits.
Old Nov 14, 2010 | 06:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
And a 97 should not have an EGR valve. And as already suggested, unscrew the o2 and leave it hang and see if it runs any better.
