no power to fuel pump
Old Nov 13, 2010 | 02:18 PM
dodgemanno1's Avatar
dodgemanno1
Default no power to fuel pump
i have power every where else but none to my fuelpump what could be wrong?
Old Nov 13, 2010 | 02:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you check fuel pump relay, fuses and ASD relay. You can swap relays from the horn for instance.
Edit, and how do you know you have no power to the pump?
Old Nov 13, 2010 | 02:32 PM
dodgemanno1
yes they all have power to them
Old Nov 13, 2010 | 02:36 PM
dodgemanno1
just no power from under hood to fuel pump
Old Nov 13, 2010 | 03:16 PM
If the engine isn't running, you will only get power there for a few seconds when the key is initially turned on. Otherwise, PCM shuts it off.
Old Nov 13, 2010 | 03:34 PM
dodgemanno1
can i run a hot wire right to the fuel pump?
Old Nov 13, 2010 | 03:43 PM
zman17's Avatar
zman17
A better and safer plan would be to trace the wires and check with an ohm meter.
Old Nov 13, 2010 | 04:00 PM
zman17's Avatar
zman17
Down load this and trace the wires, just because a fuse or relay has power going to it, does not mean there is power coming out of it. https://dodgeforum.com/forum/2nd-gen...-gen-rams.html
Old Nov 13, 2010 | 10:15 PM
dodgemanno1
Default thanks
thanks guys fixed the trouble sencer over flywheel wire was broke
Old Nov 14, 2010 | 09:48 AM
dhvaughan's Avatar
dhvaughan
that would be the crank position sensor. when it doesn't read that the engine is running, it triggers an ASD shutdown, which cuts power to the fuel pump.
