NV242 in '98 Ram
Old Nov 20, 2010 | 03:47 PM
  #21
jg09's Avatar
jg09
i found a 2 way, 4 position solenoid that I think I should be able to hook up to a switch inside the cab somewhere. it's only $45 for the solenoid, and then about $10 for a nice lighted on/off switch.
Old Nov 20, 2010 | 03:50 PM
  #22
jg09's Avatar
jg09
it's this one
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Old Nov 20, 2010 | 03:52 PM
  #23
Unless you want to be able to disengage the front axle, you don't really need the solenoid. If you do want that capability, you will need a three port, (at least) that switches source vacuum (port one) to either of the other two ports, as the actuator does not have a spring to disengage the axle.... it uses vacuum to move in either direction.
Old Nov 20, 2010 | 03:57 PM
  #24
jg09's Avatar
jg09
sorry to be a post ***** here, but couldn't i just slide the shift fork over to lock the CAD and find a way to keep it locked? Not all Dodge trucks have the CAD, so wouldn't it basically just function like a new Dodge without it?
Old Nov 20, 2010 | 03:59 PM
  #25
Yep. Shore could. Either shuffle the e-clips around to hold the fork where you want it, or, install a spring of some sort, to keep it pressed to the engaged position, or, just run a vacuum line from the original source for the switch that used to be on the t-case, to the side of the actuator that locks the front axle.
Not sure which way would be best, but, running the vacuum line would be easiest.
Old Nov 20, 2010 | 04:21 PM
  #26
jg09's Avatar
jg09
hmmm, i'll take a look at it tomorrow. I'm taking a day off from working on the truck to hang out with my girlfriend, but I'm finishing everything up tomorrow and then sending it to the driveline shop on monday.
Old Nov 21, 2010 | 01:42 AM
  #27
jg09's Avatar
jg09
if i go with the vacuum method, which hoses need to be connected? where is the beginning of the hose that delivers the vacuum?
Old Nov 21, 2010 | 07:29 AM
  #28
bjarki's Avatar
bjarki
hey there, i have a 242 TC in my Ram .. however i'm just running it in 2wd at the moment...
EDIT: i forgot to mention , i have a custom rear driveshaft and the front one is from a 1994 explorer
Old Nov 21, 2010 | 08:53 AM
  #29
I think the vacuum supply line to the transfer case switch is the white plastic line. It should hit the vacuum bag o' snakes right by the firewall, on the passenger side. Probably not going to be easy to see. Run that line to the inboard port on the CAD, and run a vent line from the outboard port, to someplace fairly high up. Should be golden.
Old Nov 21, 2010 | 02:07 PM
  #30
Hahns5.2's Avatar
Hahns5.2
So the explorer driveshaft worked? Awesome
