NV242 in '98 Ram
Old Nov 21, 2010 | 09:07 PM
  #31
jg09's Avatar
jg09
i got everything in except the front driveshaft and drove the truck home today. Fortunately for me, I have a ton of old Explorer parts (and whole old explorers) in my yard, so I should be able to find a driveshaft somewhere
Old Nov 21, 2010 | 09:08 PM
  #32
jg09's Avatar
jg09
Originally Posted by bjarki
hey there, i have a 242 TC in my Ram .. however i'm just running it in 2wd at the moment...
EDIT: i forgot to mention , i have a custom rear driveshaft and the front one is from a 1994 explorer
I have to ask, why a custom rear driveshaft? mine works just fine. Both cases are 19.25" inches (roughly) long.
Old Nov 22, 2010 | 01:43 AM
  #33
Gaius's Avatar
Gaius
Does the case to the front output seem longer? If it's the same, or minimally different, you should be able to get a new end yoke to replace the flange style that your front is. Call Six States and let them know what you're doing.
BTW, the 242 is a great t-case when it's minimally slippery. I wish the Ram had it when it's real wet and I need some grip.
Old Nov 22, 2010 | 02:35 AM
  #34
jg09's Avatar
jg09
the case to front output is the same length. the output shaft in the nv242 is much bigger and it's yolk style rather than flange style
Old Nov 22, 2010 | 07:16 AM
  #35
bjarki's Avatar
bjarki
simple , the old one was all busted and the new one has a slight correction in length, it is also made from a stronger grade of steel than the stock one and balanced as such
Old Nov 22, 2010 | 01:27 PM
  #36
jg09's Avatar
jg09
haha, fair enough
Old Dec 21, 2010 | 10:55 PM
  #37
jg09's Avatar
jg09
as an update on this project, i've put a couple thousand miles on the NV242 t-case in my Ram, but I've yet to put the front driveshaft in, so i can't comment on the AWD. however, the NV242 seems to do well behind the Ram transmission.
Old Dec 21, 2010 | 11:07 PM
  #38
Put in that front driveshaft, and give us a full report. We wants DETAILS!!!!
Old Dec 22, 2010 | 01:46 AM
  #39
pcfixerpro's Avatar
pcfixerpro
Agreed I have a guess it will work very nicely.
Old Dec 22, 2010 | 07:13 PM
  #40
lvolson's Avatar
lvolson
Sounds like what I wanted to do in my thread. Also sounds way above my level of ability.
