transmission problems?
Old Nov 17, 2010 | 03:57 AM
alfonsmax's Avatar
alfonsmax
Default transmission problems?
hi, to whomever migth help me; thanks in advance.. 1996 1500 4x4 5.9; I've been having what i think transmission problems, driving around 15-20 miles, the tach goes from 1000-2500 back and fort, like i was accelerating and releasing, on and on; i have replaced: plugs, wires, cap, rotor, idle control valve, and nothing, what should i be checking next? thank you
Old Nov 17, 2010 | 06:35 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Throttle Position Sensor.
Old Nov 17, 2010 | 11:54 PM
alfonsmax's Avatar
alfonsmax
THANKS.. I'll check it, and let you know. thanks again.
Old Nov 22, 2010 | 01:34 AM
alfonsmax's Avatar
alfonsmax
well it helped for about two days. but stil same problem. i replaced that sensor and yes it changed completely, however today it started to do the same, any more sugestions? thanks again, besides those changes i also took the cat out,
Old Nov 22, 2010 | 10:01 AM
Is the trans 'gear hunting'?
Old Nov 22, 2010 | 05:26 PM
zman17's Avatar
zman17
What brand of sensor's are you buying?
Old Nov 22, 2010 | 08:14 PM
95RAM360's Avatar
95RAM360
just an FYI, i have never had luck with any Bosche plugs/sensors in my truck.....
Old Dec 1, 2010 | 12:35 AM
alfonsmax's Avatar
alfonsmax
thanks to your responses, i just found out what the problem is. the truck came with a 5.2 engine, and some genius replaced with a 5.9, good intention however left the previous computer on truck, so its blocking the torque converter, sensors, injectors and some other things. so i today as i was driving i heard a rattle or a grinding noise, and now the 3rd gear wont engage... so i gotta figure out if i find a computer, or a 5.2 engine. and fix the transs... i dont know... thanks for your input. though.
Old Dec 1, 2010 | 01:21 AM
J415's Avatar
J415
Just curious, but how did you find this out?
Old Dec 3, 2010 | 04:54 AM
alfonsmax's Avatar
alfonsmax
i took my truck with a cooworker whom has a devise to read codes, and it was reading my computer as if my truck had a 5.2, blocking the torque converter, injectors, and sensors, causing my trasmission to engage at diff times,
