Weird roaring and vibrating from the front
Old Nov 18, 2010 | 10:38 AM
chastain90's Avatar
chastain90
Default Weird roaring and vibrating from the front
I have this weird roaring and vibrating that seems to be coming from the front right side of the truck. I replaced the wheel bearing and check the tire balance and nothing seemed to work it still does it. and it only does it around 60 mph. Any ideas? Thanks
Old Nov 18, 2010 | 01:03 PM
Possibly U-Joint? Have you checked the fluid level in the diff?
Old Nov 18, 2010 | 02:21 PM
chastain90's Avatar
chastain90
yea its fine iv had all kinds of people look at it i just cant figure it out. like i said its only at about 60 mph before that it doesnt do it.
Old Nov 18, 2010 | 03:13 PM
Rotate your tires. See if the noise moves.
Old Nov 18, 2010 | 04:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Don't think it will cause a vibration, but, roaring is also a good description of a bad fan clutch. Check it for the hell of it.
Old Nov 18, 2010 | 05:03 PM
Ooooo, good call. And, if it is bad enough, it just might cause the vibration. (that, or a failing water pump?)
Old Nov 18, 2010 | 05:06 PM
zman17's Avatar
zman17
Vibrations are hard to track down, I can't remember how many times one would swear it was the front , when the vibration was actually coming from the rear. This one is hard without actually seeing it in person.
Old Nov 18, 2010 | 05:22 PM
1998ram5.9's Avatar
1998ram5.9
Check your wheel bearing! Jack the front up and see if there if either wheels wobble
Old Nov 18, 2010 | 05:23 PM
1998ram5.9's Avatar
1998ram5.9
wow sorry never mind! I just re read your post and says you changed wheel bearings.
Old Nov 18, 2010 | 06:11 PM
chastain90's Avatar
chastain90
Wow my water Just went bad could that be it?
