No power after mudding
Old Nov 21, 2010 | 06:09 PM
Have you had a look at your trans fluid?
Old Nov 21, 2010 | 08:14 PM
CPTAFW163's Avatar
CPTAFW163
water probably went into the vent tube for your transmission. That means you have muddy water in your tranny and you have done some damage to it.
Check your tranny fluid after driving for a while. If it is chocolate, then you have your problem.
Next time, don;t go mudding in your daily driver.
Old Nov 22, 2010 | 03:21 PM
justin.gamache's Avatar
justin.gamache
Looked at the trans. fluid. From what I could tell it looks normal. It doesn't happen all the time now. When it doesn't go into first I can manually put it in and it goes with out a problem...
