Dodge Ram Offroad package or Aftermarket lift?
Old 11-23-2010, 04:43 PM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
My suggestion is to see if you can order the kit with add-a-leafs instead of the block
  #22
Old 11-23-2010, 04:44 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
Nope. Can't possibly do that. Would be far to intelligent........ (not to mention way too obvious of a solution.)
  #23
belangerbelanger's Avatar
belangerbelanger
belangerbelanger is offline
haha, just trying to find the best bang for my buck
  #24
Old 11-23-2010, 04:53 PM
belangerbelanger
kind of have a budget, any lifts that you would recommend?
  #25
Old 11-23-2010, 05:02 PM
HeyYou is offline
How much are you willing to spend?
Check the major manufacturers, and see who offers what you want, what it comes with, and how much they want for it. A few I can think of just off the top of my head:
Fab Tech
Top Gunz customs
Skyjacker
Rancho
Race Car Dynamics. (seems like an odd place for truck lifts, eh?)
Pro-comp
Etc.
And don't forget to check Summit Racing, and Jegs as well.
  #26
Old 11-23-2010, 05:03 PM
belangerbelanger
Fab Tech
Top Gunz customs
Skyjacker
Rancho
Pro-comp
Etc.
Want to spend under 1500
  #27
Old 11-23-2010, 05:48 PM
Plain Old Me's Avatar
Plain Old Me
Plain Old Me is offline
As already stated, stay away from stacking the blocks. The two main reasons for avoiding are the leverage on the springs leading to wheel hop / axle wrap, which often leads to broken parts and stability. Often blocks will come loose when more than one is stacked. Welding is not a good solution. If you must use blocks do not stack them, use one block for the total height needed. Try to avoid aluminum blocks as they are usually of a "hollow" type construction and can easily crack. Solid cast iron blocks are much better. The best way to go when using blocks to gain lift is to use whats called a "zero rate add-a-leaf". The name is confusing as it's not actually a leaf at all, but a solid steel block that is placed under the spring just like a block. The difference being that it's actually bolted to the leaf pack with the center bolt, so it becomes a part of the spring pack just like another leaf. This is the most stable and secure type of block to use. If you can't find an application for your truck these can easily be cutom made by any machine shop or even some diy'ers.
Another thing to consider is the use of air bags on the rear. There are several companies that make add-on kits that maybe you could use in combination with the blocks and spring packs to get what you're after. Very adjustable, better load handling, better ride, etc. There are also companies that sell diy components for airbag suspensions.
  #28
Old 11-23-2010, 05:51 PM
HeyYou is offline
Superlift 5"
SkyJacker 4-5"
Another skyjacker. This one is a bit more, but, has replacement rear leafs, as opposed to AAL, or blocks.
Yet another skyjacker. bit more lift here supposedly.
As you can see, there are a LOT of options out there.
  #29
Old 11-23-2010, 06:26 PM
slider15004x4's Avatar
slider15004x4
slider15004x4 is offline
At that price you could even go with BDS Suspensions 5" lift and have a lifetime guarantee.
www.bds-suspension.com
  #30
Old 11-23-2010, 07:25 PM
belangerbelanger
Going to go with the 5 inch bds lift with long arms
Quick Reply: Dodge Ram Offroad package or Aftermarket lift?
