okay need help regarding another bulletin i put up.....
Old Nov 22, 2010 | 04:55 PM
97ramnj's Avatar
97ramnj
Default okay need help regarding another bulletin i put up.....
so not to long ago i put up a bulletin about a vibration i had when id back off the gas or touch the gas 55 and above, well on the way to work today i was driving and the whole truck started vibrating like crazy and it wont stop now it comes around 40 and gets way worse at 50 and 60. now i was doing about 55 mph and put it in neutral and the vibration stayed, so please PLEASE tell me that means the transmission and transfer case are not either of the problem and its the rear axle.....i need help bad im freakin out cuz i have a brand new mega viper trans and idk what id do if that was bad....so like i said it starts around 40ish and gets worse with more speed and continues to do it even in neutral coasting...
Old Nov 22, 2010 | 06:07 PM
Aubrey's Avatar
Aubrey
Have you checked your u-joints and shafts?
Also, since you have a new tranny, make sure that the bolts holding your front shaft to the t-case are all in and tight.
Old Nov 22, 2010 | 06:14 PM
97ramnj's Avatar
97ramnj
all the u joints are good, and the shafts are good checked them all the other day, and the bolts are good also.
Old Nov 22, 2010 | 07:26 PM
97ramnj's Avatar
97ramnj
....did the forum just die out?!
Old Nov 23, 2010 | 05:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
First of all, why did you start another thread with same issue? It makes no sense. The people that replied in that one are the same people that would reply in this one. So no, the forum didn't just die out. Ask a mod to merge the two, so people don't have to give duplicate suggestions. Like I might be doing.
Now not remembering what was suggested in the other thread, have you checked the rear wheel bearings and have you pulled the cover off to see what it looks like in there?
Old Nov 23, 2010 | 10:03 AM
htrod02's Avatar
htrod02
I had the exact same thing happen to me last week. I was worried as hell that it was the trans or transfer case. Got under the truck and checked u-joints, they were tight..then it dawned on me...put it in neutral, set the parking brake and check them...sure enough the rear u-joing on the driveshaft was wobbly..changed it saturday and no more vibrations....definitly recheck those u-joints
Old Nov 23, 2010 | 12:07 PM
97ramnj's Avatar
97ramnj
well i checked the rear diff last night and i took the driveshaft off i can turn the pinion about 2 inches left and right, move it 1/4 inch up down and in and out....so im going to go ahead and assume thats why im getting a grinding and vibration
Old Nov 23, 2010 | 12:15 PM
Sounds like a pretty safe assumption to me....... This might be a good opportunity to do gears..... since I suspect you are going to need to replace the rear set anyway......
Old Nov 23, 2010 | 12:20 PM
97ramnj's Avatar
97ramnj
im putting in a dana 80 rear and dana 60 front out of a cummins instead
Old Nov 23, 2010 | 12:30 PM
That'll work.
