Thinking Of Tackling The Plenum
Old Dec 3, 2010 | 06:10 AM
  #31
Lone136's Avatar
Lone136
QUEATION? I know it would cost alittle more, but wouldn't we all be better off if we just changed the whole intake.Hughes Engines This is the one I was looking at
Old Dec 3, 2010 | 07:44 AM
  #32
95RAM360's Avatar
95RAM360
yes thats the expensive way.....you gain a little under the hood with the intake and it will handle more bolt on's but the hughes plenum kit serves just as good if you dont plan on running boost.....do the kegger mod, and you'll be good.... kegger mod, with hughes plenum kit, intake kit and bolts would be around $175 to do vs. the $599 for the intake.
Old Dec 3, 2010 | 04:18 PM
  #33
ramario99's Avatar
ramario99
just removed the intake manifold. lets see what i uncover
Old Dec 3, 2010 | 04:50 PM
  #34
Agostage's Avatar
Agostage
sweet looking intake, don't think I believe the 6mpg increase they claim though.
Old Dec 3, 2010 | 10:11 PM
  #35
chastain90's Avatar
chastain90
what is the kegger mod? iv heard this around the plenum stuff im thinking of tackling mine. but i would like to know what kind of difference in power and/or mileage can be seen. mine does seem kinda sluggish.
Old Dec 3, 2010 | 10:18 PM
  #36
chastain90's Avatar
chastain90
also does the intake lone136 was talking about already have the plenum on it?
Old Dec 3, 2010 | 10:48 PM
  #37
Kegger Mod.
The stock intake has a plate on the bottom of the intake plenum. (I am sure that is a latin word meaning "empty space"......) The plenum itself is just the chamber that the intake runners draw air from. From the factory, the plate that seals the bottom of that chamber is steel, and the bolts that hold it in place are a shade to long, so, a blown gasket for the plenum plate is extremely common, if not universal, to any engine that uses this particular manifold.
The Huges/Mopar Performance manifolds are a completely different design, and have no plate on the bottom of the plenum, so, while they are expensive, it is indeed a 'permanent' fix. Of course, using the hughes plate, gasket, and bolts, is supposed to be as well, and is a hell of a lot cheaper. Not to mention you get to keep all of your bottom end torque by NOT changing to a different style manifold. (there have been a few threads on THAT topic as well....)
Check out the article, its actually pretty good, and even has pics.
Old Dec 5, 2010 | 08:23 PM
  #38
ionakana's Avatar
ionakana
I have the hughes plate and I'm getting ready to tackle this soon as well. Should I have bought the bolts from hughes or are they identical to the existing bolts? If the existing bolts are to long, will they be after install the hughes plate becasue it's 1/4" thick?
Old Dec 5, 2010 | 11:42 PM
  #39
DodgeRam10's Avatar
DodgeRam10
im going to get new bolt from hughes, but i was wondering the same thing, if they are going to bottom out like the original bolts or not, but i think i remember hearing about people grinding off a little on the ends because they aren't threaded all the way down but not sure if they did this to old or new bolts?
Old Dec 7, 2010 | 12:14 AM
  #40
jswain's Avatar
jswain
Always use new intake manifold bolts. The bolts that hold the plenum to the intake, you could probably reuse. No need to cut them shorter if you're using the 1/4 inch plate. I got new bolts from hughes when I did mine, just felt safer not reusing the old ones, although I doubt its absolutely necessarry to use new ones. Do the bolts not come with the new plate? I bought the entire kit from hughes.
