Thinking Of Tackling The Plenum
Old Nov 25, 2010 | 12:15 PM
DodgeRam10's Avatar
DodgeRam10
Default Thinking Of Tackling The Plenum
So does the hughes kit totally eliminate the problem? also is this the "keg kit" everyone talks about. heres what i was looking at,
http://www.hughesengines.com/Index/p...p?partid=26190
anything else i should get? My valve cover gaskets are leaking so i was thinking of doing those when i do, anything else though,
- I'm aware of the shipping errors of Hughes-
Old Nov 25, 2010 | 12:28 PM
DodgeRam10's Avatar
DodgeRam10
also didnt know if i should just get the plenum plate from hughes for $75 and get fel pro gaskets else where or if i should get the kit above
Old Nov 25, 2010 | 12:58 PM
aarons ram's Avatar
aarons ram
If anyone knows, how critical is it that this gets done? I dont have much into money and i wanna replace the fluids in my trans and rear differ before doing anything else on my truck.
Old Nov 25, 2010 | 01:02 PM
Saber6's Avatar
Saber6
I got that kit. The gasket kit that came with it had two of those curved rubber gaskets rather than one curved, one strait. I ended up purchasing a second gasket kit. I had to request a refund for the kit Hughes sent me. They made things right without too much difficulty.
I ended up going with the Fel-pro gasket. It looked much more substantial than the gasket in the Victor Reintz kit Hughes sent.
I'd recommend the plenum plate from Hughes, but go to a part store and get the Fel-pro gasket kit.
Old Nov 25, 2010 | 01:08 PM
Saber6's Avatar
Saber6
Aaron,
Some say all 2nd gen Ram will have the blown plenum gasket. I did the test and the test showed it should be intact (according to the vaccuum / pressure gauge). Based on advice from those "in the know", I went ahead and changed it out. It was, in fact, perfectly intact.
That being said, you have to go with the odds. Ram mechanics claim it's a huge weakness in the engine. It's worth several hours of your time and about $100 for peace of mind. If it is blown, or blows in the near future, problems with your catalytic converter and O2 sensors will start (not to mention bad MPG and no HP).
Do your fluid changes and look into that plenum fix. Just my opinion....
Old Nov 25, 2010 | 01:18 PM
DodgeRam10's Avatar
DodgeRam10
ok so get the hughes plate and order fel pro plenum gasket and intake gasket and what about the bolts
Old Nov 25, 2010 | 01:24 PM
DodgeRam10's Avatar
DodgeRam10
also which kit of fel pro should i get or do i need
http://www.oreillyauto.com/site/c/de...2293&ppt=C0026
or
http://www.oreillyauto.com/site/c/de...4727&ppt=C0026
Old Nov 25, 2010 | 03:19 PM
The first one. comes with all the gaskets you need. Also get new intake manifold bolts. They are NOT re-usable.
Have Hughes send you the bolts for the plate as well.....
Old Nov 25, 2010 | 08:18 PM
bmyze316's Avatar
bmyze316
My Hughes kit will be here Tuesday. How hard is it to install? I'm not to confident I can do it. I have changed the air filter, brakes, thermostat and plugs but thats about it. Im thinking of bringing it to a mechanic to do it how much would a mechanic charge?? I probably be willing to pay a couple hundred but not much more than that but then again I dont want to try it myself and jack it up
Old Nov 25, 2010 | 08:36 PM
Its really not that bad of a job. Biggest problem I had was the front two intake manifold bolts broke, and they were a bit of a drag to extract.
Paying a shop to do it.... you are looking at at LEAST 4 hours.... probably more. So, multiply that by labor rate...... gets expensive quick.
