? about voltage
Old Nov 26, 2010 | 08:12 AM
thompson1986's Avatar
thompson1986
Default ? about voltage
what does everyones volt gauge show? mine is almost always above the 14 mark but still in the green area, ive tested the altenator and it works jsut fine 14.xx volts every time. just curious, dont want to tear things up if theres nothing to worry about
the needle is jsut above 14
Old Nov 26, 2010 | 08:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
It's perfectly normal.
Old Nov 26, 2010 | 09:34 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Anything up to about 14.6 is normal in any 12v automtive electrical system while the engine is running.
Old Nov 26, 2010 | 09:55 AM
95RAM360's Avatar
95RAM360
mine is past the 14....so id say mines running about 16 volts....mines just about to the high side of operatering range.....and i run subs....
Old Nov 26, 2010 | 09:59 AM
Sixtysixdeuce
Check it with a quality volt meter. I doubt it's that high. If it is, you need to make sure the engine and battery are properly grounded to each other and the chassis. If not a ground problem, replace the alternator. Voltage regulators in the PCM can only cope with so much.
Old Nov 26, 2010 | 10:02 AM
95RAM360's Avatar
95RAM360
its always been like that since i bought it....ive had it for a year and three months now.
Old Nov 26, 2010 | 10:09 AM
zman17's Avatar
zman17
If its just past the 14, thats not 16 volts. It would have to be on the white line that is between the 14 and 18.
Old Nov 26, 2010 | 10:27 AM
95RAM360's Avatar
95RAM360
its not quite to the line...take the thickness of the needle...its less then half of that to the line....
