Bodylift questions....
Old Nov 28, 2010 | 01:28 AM
  #21
99dodge318's Avatar
99dodge318
yeah my bad a did not mean to direct that reply at you but at your question.
Old Nov 28, 2010 | 06:52 AM
  #22
TheBigRedOne's Avatar
TheBigRedOne
No worries man, we're straight.
Old Nov 28, 2010 | 09:48 AM
  #23
Silver_Dodge's Avatar
Silver_Dodge
Originally Posted by TheBigRedOne
Working space? Dude, the frame, the axles, everything is going to sit at the exact same height. All its going to do is lift the BODY off the frame. Ur gonna have some sweet gaps.
And yeah, it will make even more top heavy because the weight is being shifted up.
Actually, a BL makes it less top heavy then a suspension only lift. With a suspension only lift, you put the body AND the frame up higher (and everything attached to the frame like the engine and drivetrain). With a BL, just the body goes up, the frame stays lower, so all that weight of the frame, engine, etc... stays lower too. This actually allows for a better center of gravity then when you have both the frame and the body up in the air like with a suspension only lift.
As far as gaps go, you may have them, but on 2nd gen rams you can not see them thanks to the wheel well liners that Chrysler put in the trucks. Notice that on Fords and Chevy's with BL's, you can see those gaps because the wheel wells are wide open.
Old Nov 28, 2010 | 10:02 AM
  #24
TheBigRedOne
Why do it at all if you don't need to clear larger tires..? And raising weight is raising weight, you cant make anything better by doing that. That's just silly to even think about. And these trucks have epic body gap, its realllly bad under the tailgate.
Old Nov 28, 2010 | 10:19 AM
  #25
TheBigRedOne
That's why most 'good' body lifts come with bumper relocation brackets.
There's no such thing as a good body lift. And those brackets are a joke. They take your somewhat functional bumper and turn it into a show piece. Not to mention it sits higher then it really should for a street use vehicle, thus halving its effectiveness in a collision.
  #26
TheBigRedOne
So hey, today is forum misplacing stuff day. lol
Old Nov 28, 2010 | 10:21 AM
  #27
Old Nov 28, 2010 | 10:45 AM
  #28
Silver_Dodge
I do agree that there is not a lot of good reasons to do a BL if you are not going to run larger tires. The only other gain from doing a BL that I can think of is better room in the engine compartment to work on the top of the engine.
My truck has a 3" BL on it, and there is no noticable gap like you see on other manufacturers. Far far cry from "epic" thats for sure.
Old Nov 28, 2010 | 11:36 AM
  #29
TheBigRedOne
Any gap is epic gap. Any gap is too much gap. You're weakening the overall integrity of the body by lifting it up off the frame on stilts.
Old Nov 28, 2010 | 12:09 PM
  #30
Silver_Dodge
Ok. thanks for your opinion.
