Ram 1500 Nv4500 Swap
Old Dec 2, 2010 | 06:13 PM
PurplDodge's Avatar
PurplDodge
I know it has the 360 is there something diff because it in the 3/4Ton?
Yeah, the 3/4 ton and 1 ton 5.9L V8s (Mopar calls them HDC) has an air injection pump and EGR.
Good luck on the NV4500 swap. I've been thinking real hard about doing this myself!
Old Dec 2, 2010 | 06:24 PM
Not all of them... I think just the 94-95 trucks. Mine is 96, and no AIR pump, and no EGR either.
Old Dec 2, 2010 | 06:39 PM
dodgeboy7's Avatar
dodgeboy7
Yea my donor truck did not have egr or air pump so is there any other diff
Old Dec 2, 2010 | 06:41 PM
PurplDodge's Avatar
PurplDodge
On half tons, yes that is true. But on 3/4 and 1 ton models, its all years. In my owner's manual the maintnance section has a part about the maintnance of the EGR system. 3/4 and 1 ton 360s and 488 V10s have a light on the dash that indicates if the PCV valve or Oxygen Sensor needs replaced.
Old Dec 2, 2010 | 06:46 PM
Mine is a 3/4 ton. No AIR pump. No provisions for it. No bracket for it. No ports in the exhaust manifolds for it, no piping to the cat for it. It didn't come with it.
There is an egr block off plate on the original manifold, but, no provisions on the exhaust manifolds to supply a valve with the requisite gases. No lite in the dash, and no EGR codes have ever come up. I suspect that the block off plate is factory installed, I can come up with a variety of reasoning for it. (such as, using up the last of the EGR capable manifolds, before going to the new design in 97 that didn't have any EGR provisions at all.)
Old Dec 2, 2010 | 06:49 PM
PurplDodge's Avatar
PurplDodge
Well damn. Maybe it is just newer ones then. I'm positive my 1999 owners manual mentioned EGR on the 3/4 tons.
Old Dec 2, 2010 | 06:50 PM
dodgeboy7's Avatar
dodgeboy7
So they is no real diff in the block?
Old Dec 2, 2010 | 06:53 PM
Nope. Motors are exactly the same. (as long as the vin code is the same..... )
You can swap everything from your motor, over to the 360, so the sensors and such are correct for what the PCM expects, and reflash your PCM for the larger motor, and down the road you go. (you have a 5.2 currently don't you? If you already HAVE a 5.9, its a direct swap, switch the sensors and such anyway though. )
Old Dec 2, 2010 | 07:32 PM
dodgeboy7's Avatar
dodgeboy7
I am not swap that motor in there it had a knock and smoke alot lol. I am keeping it for a furture 408 hopfully this summer. And yes i have 5.2 so i got to get dodge to reflash it and just my vin number in the swap over pcm. But i am useing the engine hardness and pcm off my donor truck.
Old Dec 2, 2010 | 10:48 PM
99dodge318's Avatar
99dodge318
i wish i could find a donor truck like that.
are the frames for the 3/4 ton any bigger/beefier?
i would have just swaped motors and cabs and be rolling on 2500 running gear and frame since both trucks are the same wheel base.
