Ram 1500 Nv4500 Swap
Old Dec 4, 2010 | 05:05 PM
  #21
dodgeboy7's Avatar
dodgeboy7
I think the frame is box in parts but i wanted to do it this way plus my axles are all new with 4.56's plus this truck needed to be put down a long time ago. It was ruff!!!!
Old Dec 5, 2010 | 02:36 PM
  #22
dodgeboy7's Avatar
dodgeboy7
Well trying to figur out why my turn sign dose not work little recap this started after i swap dashs so something to do with that i am guessing.
-Left turn signals work fine
-Right rear turn signal works
-The little green arrow in dash dose not work for right turn
-The front right turn signal dose not work either
-It dose not matter if it the turn signal or 4 ways both do the same thing
-Have power coming out of flasher
-No power to the pin for the dash
-No power to the front right turn signal either
Any ideas????? kinda lost wish i had a good wiring dram for my truck
Old Dec 5, 2010 | 03:27 PM
  #23
Check the ground wire for the right front turn signal. Should be a black wire.... not sure where it actually runs off to.
Old Jan 17, 2011 | 12:17 PM
  #24
dodgeboy7's Avatar
dodgeboy7
Well i been kinda of lazy and not posting my progress just cause i have not done much due to lack of money (i am a collage stundent). But i worked over the break and last weekend i sold my dana 60s and now have the cash to finsh my project i started. So my fly wheel and clutch is all order and well hopfully get the transfor case back together next week once i bring it to school so i can use the press and the pullers. The only thing i can think of that i still need to order or find is the shifter boot cover. The one in the other truck was falling apart. I tryed find them online anywere and cant find it so i think i am stuck buying from the dealer.
Old Jan 17, 2011 | 12:35 PM
  #25
Try LMC Truck as well. Or a junkyard......
Old Jan 20, 2011 | 11:04 AM
  #26
dodgeboy7's Avatar
dodgeboy7
Well cant find a shifter boot dodge cant get them so i pretty much stuck making something but that well wait till i am do.
But any way back to the swap. My goal this weekend is pull my trans and have my new one bolted in. I have a new fly wheel with new fly wheel bolts and clutch. Only thing i dont have is bolts to bolt the clutch to the flywheel. Cant find part number anywere and not sure if i can use like a grade 8 bolt or not?
Old Jan 23, 2011 | 10:35 PM
  #27
pavement_hater's Avatar
pavement_hater
I lucked out and found a truck in a nearby yard that still had the floor console boots and all in it. I was also able to grab the dash pocket.
Old Jan 23, 2011 | 10:54 PM
  #28
pcfixerpro's Avatar
pcfixerpro
What is the name of the yard you go to?
Old Jan 25, 2011 | 02:31 PM
  #29
dodge15004x45.9's Avatar
dodge15004x45.9
I bet its mason dixion lol.
Old Jan 25, 2011 | 02:46 PM
  #30
pcfixerpro's Avatar
pcfixerpro
Highly doubt it. They haven't had a manual 2nd gen, let alone any new 2nd gens in the yard in the past 4-5 years.
