Vent Selector is stuck????
Old Dec 2, 2010 | 09:47 PM
KY BIGRAM's Avatar
KY BIGRAM
My '94 done the same thing. I only use the truck for 4 wheeling so I just disconnected the lever under the dash and switch it by hand.
Old Dec 3, 2010 | 10:30 AM
HDRAMman's Avatar
HDRAMman
Now that you all mention it, I did notice that under pressure the vent would stop bowing. My truck caught wildvents, dirty truck. hahaha.
So, where should I start my traceing at? is there a typical area that usually gets affected? Is there a map of just the vacume tubes and how they run in any manual?
Old Dec 6, 2010 | 03:03 PM
HDRAMman's Avatar
HDRAMman
Nothing? No other wildvents survivor with any advice?
Old Dec 6, 2010 | 04:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Read this thread to fix it https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Feb 22, 2013 | 12:15 AM
bigblueownerjon's Avatar
bigblueownerjon
Default corection and wild vents is realy justa loss off vacuum
That is indeed wild vents, and is usually caused by a failed check valve up by the intake manifold. I think there is a DIY fix thread in the FAQ section for it.
actualy in most cars under heavey acceleration while A/C is on the computer will turn off A/C to give more power to the wheeles because even tho A/C doesnt use muc power it still uses power needed under heavey acceleation
Old Feb 22, 2013 | 01:31 AM
ReadRam's Avatar
ReadRam
Start following the vacuum line off passenger side of intake, they branch off a couple time and that's where the checks valves live. You more than likely have a cracked line before they disappear into firewall, which will default the vent to defrost only. But yeh, search wild vents. If after fixing the break and you still get get switching to defrost when accelerating, then you need to replace the check valves also. 8.00 from dealer.
Old Feb 22, 2013 | 11:22 AM
The PCM will turn off the COMPRESSOR, not the blower fan.
I would also point out this thread is more than two years old.......
Old Feb 22, 2013 | 03:07 PM
bigblueownerjon
srry thank you for making what i was saying more clear but even tho its 2 years old it can still help some one else out like my self
Old Feb 26, 2013 | 10:11 AM
JoshHager's Avatar
JoshHager
I just recently noticed my vents having issues and I am just starting to learn about this stuff. I had no clue what was going on but after reading this old thread it has help clear somethings up.
I do have a question though. My controller is stuck in defrost and I did find that I have a broken vacuum line. It is just off of the check valve and is the line that runs through the fire wall. How difficult is it to replace this vacuum line?
Old Feb 26, 2013 | 10:20 AM
Just splice the line with a piece of rubber vacuum line. The plastic lines LOVE to get brittle, and break...
