gauge pod install
Old Dec 5, 2010 | 12:34 AM
matty675's Avatar
matty675
ok so i could get away with splicing all 3 wires together and hooking them directly to a single fuse tap? why are there 2 fuse spots on the top of the fuse tap?
Old Dec 8, 2010 | 12:46 AM
matty675's Avatar
matty675
bump.....
Old Dec 8, 2010 | 11:06 AM
aim4squirrels's Avatar
aim4squirrels
If you splice all three together and one shorts out, it could short them all. The best way is to have a single positive feed from a switched source, like the cigarette lighter, to a fuse block that separates out to 3 separate feeds and powers each gauge. You can use a common ground for all of the gauges.
As far as wire is concerned, run the same gauge or slightly larger from the point that you tap the cigarette lighter to the fuse block to account for any additional resistance. For the ground, I always go.a gauge larger than than the feed, as you can't really overground.
Old Dec 8, 2010 | 11:21 AM
Gerehead8's Avatar
Gerehead8
There are two fuse spots on the tap to cover both circuits. One for the circuit you tapped into (use fuse the fuse you pulled) and another for the new power lead.
Old Dec 8, 2010 | 01:28 PM
99dodge318's Avatar
99dodge318
i have one of those add-a-circuit powering my gps, i removed my radio fuse pluged that in put two fuse in it and now my gps comes on when i start the truck
Old Dec 8, 2010 | 02:49 PM
matty675's Avatar
matty675
if i get a short, all i have to do is replace the fuse right?
Old Dec 8, 2010 | 03:02 PM
No, you need to FIX the short, and THEN replace the fuse.
Old Dec 8, 2010 | 03:32 PM
matty675's Avatar
matty675
it wouldnt damage any of the gauges would it?
Old Dec 8, 2010 | 03:41 PM
Supposedly, it shouldn't. In actual practice? How's your luck?
Old Dec 8, 2010 | 11:59 PM
matty675's Avatar
matty675
haha. how about using 3 fuse taps, 1 for each gauge?
